Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-02-2006, 07:27 PM
UncaringMrBC UncaringMrBC is offline
has anyone had this problem?
i know that i have an oil leak on the part that my oil filter screws into but im not sure if that is what is makin this happen....my check engine light comes on when i let off the gas while driving...i have to let off of it for like 4 or 5 seconds before it comes on and it goes off when i push the gas again....just wondering if anyone has ever had this problem....ill post back when i find the solution....92 tsi...all stock
Old 03-02-2006, 07:46 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Re: has anyone had this problem?
For the leak. Are you sure the filter is screwed in right? I know its one of those uhh DUH things but, I am just trying to be helpful.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 03-02-2006, 10:32 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Get the code read. I doubt it has anything to do with your little leak.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 03-04-2006, 09:15 AM
atemesiro atemesiro is offline
using a gage check the real oil [pressure is very likley that is the oil pressure sender who leaks
