93 Caprice Timing Marks V8 305 E
I have a 1993 Caprice W/ 305 V8 E engine. The timing marks have about four "teeth" but it's so corroded that the degrees are not readable. There is one large tooth with a wide valley and then the remaining teeth to the left are the same size. The engine labels state that the setting is 0 degrees. Does anyone know which point/tooth or valley(between the teeth) is 0 degrees. Looks similiar to this VVVV
Re: 93 Caprice Timing Marks V8 305 E
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Code 32 is Exhaust Gas Recirculation (EGR) system. If it is giving a code, chances are it is either sticking open or closed, allowing too much or too little EGR flow.
