Old 03-02-2006, 04:54 PM
Dseries_lover Dseries_lover is offline
Don't you guys hate newbs like me.....
well i love hondas and am new to them... i really need to know how to take the transaxle out on my 91 hatch si
Old 03-02-2006, 04:57 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: Don't you guys hate newbs like me.....
Well first off, naming the title that is completely something different that what your asking is going to be a noob thing and second, we all were noobs sometime or another. How else are you going to learn something? Welcome to the forums by the way.
The transaxle should be an unbolt affair as it's not hard to do at all. Do a search on it using the search engine. You'll find loads and loads of stuff on this forum. GL
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 03-02-2006, 05:23 PM
well thanx man. i have a few other questions to ask as well. they may sound dumb but im a newb. 1.Can i put a d16z6 head on my d16a1.considering they are both 1.6?
2. what would be a cheap 2000 dollar swap for my car after this summer?
Old 03-02-2006, 05:40 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Z6 head on an A1?
This will not be a direct bolt on. Everything will line up, except the head bolt hole closest to the distributor will be about 1/4" out of alignment. Then there is also a timing belt issue since the TB pulley is set up for a DOHC motor, you will need to make a bracket to relocate the TB idler pulley.
This has been done, but it is not an easy swap.
Also, by using the Z6 head on an A1 you will be increasing the compression ratio ALOT!
If you meant to type D16A6 instead of D16A1, then the head will swap right over.
If you do have a DOHC D16A1 in your car, then focus on getting more power out of it with cams and a header, etc. The D16A1 motor can make 150-160 HP pretty easily with the right parts.
Old 03-02-2006, 05:44 PM
well i waswrong and meant d16a6 my bad.. but with the a6 will i have to do any other swaps along with it?or will it just bolt on?
Old 03-02-2006, 09:34 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Well except for the wiring for the vtec, if you use your old harness and injectors, I believe the distributor is the only thing that'll be an issue, and I think its just a matter of swapping a plug for the OBD-0 one....
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
