Old 06-30-2002, 04:40 PM
phathatch phathatch is offline
Arrow red/clear taillights conversion? on a 4g civic hb
Dose anyone know how i could get my taillights to look like the picture below with the red/clear taillight on them
someone told me that they painted the upper part of clear taillight lenses
candy apple red
but there might have to do bulb relocating do i? if so how would do that?
i know the paint color is candy apple red but what type of paint or material do i used?
Old 06-30-2002, 04:46 PM
zigen zigen is offline
Send a message via ICQ to zigen Send a message via AIM to zigen
The brand of the paint is called Testors. You can find it at hobby stores since they use it for model cars and such. It's only like 3 bucks and make sure you get the clear coat to.
Old 06-30-2002, 05:13 PM
88ReX 88ReX is offline
HEy man what ype of clear coat do you suggest, I got some krylon clear. I sprayed mine like 2 weeks ago and then clear them however the clear spat out globs of clear leaving little "bubbles" needless to say im getting a new pair of tails b/c of how the clear fucked them up....
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 06-30-2002, 06:06 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
I used Testor's clear coat, it worked out great for me, no globs or anything, just make sure you put a nice thick layer and guaranteed it won't fade.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 06-30-2002, 07:37 PM
Arrow no relocations?
so all you need to do is put a testors clear coat and clear taillight lenses
to create red/clear taillights
or do i have to relocate some bulbs?
Old 06-30-2002, 08:33 PM
91hondaguy 91hondaguy is offline
so u saying....
so to make this clear.
all i haf to do to make mine taillights like those
is to:
buy tester candy apple red paint and apply directly on the top part
and clear coat it .
and for the bottom half
all i haf to do is to clear coat them
is that right??
please correct me..
i own a 88 yellow CRX
www.northwestshowoff.com
Old 06-30-2002, 09:09 PM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
if you truely want them red/clear and light up respectively, you gotta redrill holes and eliminate the stock holes. you also have to tear them apart, and put something in to divide them. its a pain in the ass but it can be done. as for the holes, get a 1" drill, and drill the holes where you want them, then get out the good old pocket knife and try cutting the notches as close to stock as possible. oh yeah, you might have to do some creative hacking to the metal that is behind the taillight assembly in order to accomodate the new bulbs locations.
Old 06-30-2002, 09:21 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
is there any way to get the orange out of the stock tails on the 90-91 sedan?
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 06-30-2002, 11:25 PM
91civicDXdude's Avatar
you know actually those tail lights look like tail lights off a 2nd gen integra. if you knew about body molding fiberglass it wouldn't be hard considering people transplant supra tail lights onto 92 style civic hatch back
Old 07-01-2002, 12:03 AM
Melt's Avatar
All I know about body molding fiberglass is that it is expensive!
AF Bay Area Crew
Old 07-01-2002, 04:46 AM
Re: so u saying....
is to:
and clear coat it .
is that right??
please correct me..
Well you have it all right except, dont put any paint on the bottom part, especially clear coat...putting clear coat on the clear section will make it yellowish....just leave the bottom section alone
-2000 Civic Hatch
-1998 Lexus SC300
Old 07-02-2002, 07:11 PM
Well I also used the Testors brand High Gloss clear cloat and I think it came out well. Only difference is I started out with some Generation 1 altezza style tail lights and marked off the bottom half with tape and painted the top the Candy apple red. Personally I think it is the best looking mod I have done. IF I had a working scanner I would post some pics.
Old 07-02-2002, 07:35 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
This probably wasn't due to the paint. I've had this happen under 2 different circumstances. If your finger gets in the way of the spray from the nozzle on the paint can, the paint (or clearcoat) will build up on your finger, and the spray will then blow it off your finger in drops instead of a particulate mist... Another time, I bought a plastic pistol-grip attachment for aresol spray paint cans. It clips to the top of the paint-can, and when you pull the trigger, a lever pushes down on the spray nozzle. The problem with this is that the paint has to spray through a hole in the plastic attachment, and (just like with the finger example) paint builds up on the edges of the hole, then gets blown off as drops by the spray.
So If you had this problem, I'd imagine that your finger got in the way.
Just my $.02
