Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-02-2006, 02:05 PM
topbro2's Avatar
topbro2 topbro2 is offline
parts swap
would a 95 240sx's engine fit in a 92's and will the shock and spring fit also let me know thankx
Old 03-02-2006, 04:32 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Re: parts swap
The suspension won't fit between the S13 and S14, but the engine will, there are a few minor things you have to sort out I believe.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 03-02-2006, 05:05 PM
sidewayzS13's Avatar
sidewayzS13 sidewayzS13 is offline
doin it sidewayz
Send a message via AIM to sidewayzS13
Re: parts swap
simple yes and no
Old 03-02-2006, 06:46 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: parts swap
basically everything you take out from the 92 can be taken from the 95 and be put in. power steering might be an issue but shouldn't be.. trannys should be the same.. other than that its something you can most likely figure out as you're going. if you're gonna run into problems then its gonna be shit like a/c, power steering, that kinda shit that takes up space in the engine bay.
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 03-02-2006, 06:54 PM
stang805's Avatar
stang805 stang805 is offline
Send a message via Yahoo to stang805
Re: parts swap
might be wrong but i believe the rear end has to be swapped too cause the speed sensor on an s14-s15 is in the rear but not on s13
Old 03-02-2006, 07:10 PM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
Re: parts swap
i could be wrong, but i believe that is only on the s15
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
Old 03-02-2006, 11:03 PM
Re: parts swap
It's only the S15 SR20 that has the speed sensor in the diff.
-Jonathan
Montreal, Canada
Old 03-02-2006, 11:23 PM
Tims_240's Avatar
Tims_240 Tims_240 is offline
Re: parts swap
http://forums.nicoclub.com/zerothread?id=149063
merry christmas.
mods list: t3/t04e, iap oil lines, iap i-c piping, xspower i-c, z32 mafs, enthalpy tuned ecu, 615cc injectors, s14 tomei fuel pump, blitz DD bov, tial 38mm w/g, BD exhuast mani./downpipe, Spec StageIII clutch .
.s13 power.
power estimate at ~ 270 whp @ 11 psi.
