Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-02-2006, 12:55 AM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
idling at a higher rpm help
My Car used to idle typically at less than 1000rpm, now it goes about 1.5, i heard a noise before it sounded like a whistle on a tea kettle when the tea is warm...
how do i detect air leaks, i think a whose may be slightly ruptured, but im not sure...
what is idling higher than usual a symptom of ?
any input?
T R U E E C L I P S E
1996 MITSU. SPYDER ECLIPSE
[email protected]
http://www.cardomain.com/ride/653950
Old 03-02-2006, 02:41 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: idling at a higher rpm help
run a boost leak test. It will find the leak. If no leak shows up, it's probably a faulty ISC motor. If the idle goes up and down from around 1000-1500, and the AC isn't on, then it's usually the ISC motor. My ISC isn't working, it doesn't really bother me, you can always just unplug the TPS and set your idle with the BISS screw, as long as you don't mind the CEL.
now - 2000 civic
soon - 2002 is300
Old 03-02-2006, 03:18 PM
i am not turboed unfortunatley =[, what is a boost test?
[email protected]
Old 03-02-2006, 07:33 PM
SLoe's Avatar
SLoe SLoe is offline
Spray with WD40, or carb cleaner around TB and IM runners and base. If it is a vacuum leak when you spray your idle will change. Spray with soapy water, will find air leaks also. Look for the bubbles, or change in idle.
any input?
Vacuum leak possibly.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
