Old 03-01-2006, 10:56 PM
mountie1982's Avatar
mountie1982 mountie1982 is offline
How do you clean your MAF sensor?
I want to clean my MAF sensor. I know to use brake cleaner and a soft brush or cloth. I dont know if I should remove the whole thing out of the truck or can you do it while its attached. Its a 97 blazer 4.3l 4x4, where is the sensor and what does it look like. I think i know but not 100% sure.
2006 Dodge Ram 1500 Quad
Why Dodge it when you can RAM IT?
1964 Vw Baja 1600
Old 03-02-2006, 11:47 AM
muddog321 muddog321 is offline
AF -Advisor
Re: How do you clean your MAF sensor?
Its in the air cleaner assembly (96 up) right above the filter housing in the round metal housing - just disconnect the flex coupler between the filter and MAF housing and spray it with brake cleaner that evaporates - do not scrub it or break the 2 wires - expensive. Works great and only takes a few minutes.
Old 03-02-2006, 03:36 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Brake cleaner is not the best stuff.
Use fast dry electrical contact cleaner.
No brushing. Just spray and let dry.
And the hit it again for good measure.
CRC now has a MAF sensor cleaner that works good.
MT
MT
Old 03-03-2006, 07:18 AM
nickledimed's Avatar
nickledimed nickledimed is offline
Send a message via Yahoo to nickledimed
I wouldnt us a brush or a cloth becouse you are taking a chance of breaking the sensors I use carb cleaner and it does just fine.
08 Equinox LT
Old 03-03-2006, 09:05 AM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
i use a qtip and electric cleaner spary havnt tryed thee maf cleaner yet but will soon
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 03-03-2006, 03:15 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
My procedure exactly. I had a DTC which could be my MAF meter. I sprayed it with no-residue electronic cleaner and the code disappeared. Good enough for me.
Learned my lesson. I put a lot less oil on my air filter element now.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
