Is 10w-30 Giving a Bad Mileage?
Hey guys I have been using the Mobil 1, 10W-30 for my 2004 3.3L Town and Country, for the last couple of oil changes. The recommended oil for my car is the 5W-30 though. I was using the Mobil 1, 5W-30 before I started using the current oil. Do you guys think that the 10W-30 is bad or good for the gas mileage compared to the 5W-30. Also does the 10W-30 provides better engine weat protection compared to the 5W-30 because the 10W-30 is thicker. All the help would be appreciated.
Re: Is 10w-30 Giving a Bad Mileage?
Don't know for sure but logically you would think a thicker oil would decrease your milage so I vote for that side. I 've heard plenty of people say that's the case but, haven't seen anything difinitive. All I know is I use the thinner 5w-30 during the winter and the thicker 10w-30 during the summer. I haven't noticed a difference in mileage. I'd bet the difference is so small you probably would have a hard time noticing.
I do know that the next new vehicle I buy I'm using Amsoil. I've seen a lot of people in the know speak highly of it. A buddy of mine started using it in his Highlander and said his mileage went up close to 2 mpg right away. He went the whole nine yards and installed their secondary filter and uses Amsoil filters exclusively. Amsoil and filters are a bit more expensive but, generally you get what you pay for. He said it's not recommended to switch to Amsoil if your car has higher mileage. Food for thought. |
From everything I have ever read concerning oil and viscosity levels, 5w-30 would be for colder climates.
The 5w and 10w signify the weight or viscosity of the oil when it is cold. The 30 is the weight when the oil is warm. So basically after your car is warmed up it is the same oil, and would make no difference in mileage. The idea behind it is that much wear takes place in your engine on the initial start up, especially if it cold out. If it is cold out during the initial start up and you have thick oil, your engine is not receiving proper lubrication until your engine starts to warm up, thereby thinning your oil. However if you are using 5w-30 your oil will be thinner from the get go and start protecting your engine earlier then the 10w-30 does when it is cold out. At least that is my understanding, and i'm sticking to it. Long story short, if you live in a cold climate, use 5w-30 in the winter, and use 10w-40 in the summer. Your mileage won't change with either. |
When comes to the viscosity of motor oil, about all that most people understand is that the higher the number, the thicker the oil. Now this is true, but there is more to it than that. I learned quite a bit more about viscosity when I studied mechanical engineering in college.
Viscosity is a measure of internal frictional resistance of a fluid. Every fluid on earth has its own viscosity characteristics. In addition, the absolute viscosity of any fluid decreases with a rise in temperature. In other words, the warmer a fluid becomes, the thinner it becomes. Years ago, the Society of Automotive Engineers (SAE) developed a specific set of standards for the viscosity of lubricating oils, called the SAE viscosity rating. The SAE viscosity rating can vary from 0 to 150. The fluid with any specific SAE viscosity rating has a specific absolute viscosity that varies consistently on a logarithmic scale over a specific range of temperatures. One interesting characteristic is that the absolute viscosity of one grade of oil at one specific temperature can be the same as another grade of oil another specific temperature. For example, SAE 50 oil at 200F has the same absolute viscosity as SAE 40 oil at 175F, SAE 30 oil at 160F, SAE 20 oil at 145F, and SAE 10 oil at 115F. Now, multigrade oils are different from single grade oils. These oils do not thin out as much over a range of temperatures as a single grade oil. The SAE viscosity rating uses two numbers. The first number in the rating of a multigrade oil indicates that the oil has the same absolute viscosity as the single grade oil of the same number at ambient temperature. The second number in the rating indicates that the oil has the same absolute viscosity as the single grade oil of the same number at operating temperature. For example, let us look at SAE 5W-30 motor oil. SAE 5W-30 oil has the same absolute viscosity as SAE 5 oil at 50F. It also has the same absolute viscosity as SAE 30 oil at 190F. Now let me explain this in simpler terms. If you put SAE 5W-30 oil in your engine, this oil will be like having SAE 5 oil in your engine when you start it up on a cold morning. Once the engine warms up to operating temperature, this oil will be like having SAE 30 oil in your engine. The only benefit you get by using either SAE 5W-30 or 10W-30 over SAE 30 oil is lower flow resistance at start up. Once the engine warms up, there is no difference. In addition, the difference between SAE 5W-30 and 10W-30 is miniscule and, again, the only benefit is at cold start up. Now, some people out there think that the thickness of their motor oil can have a significant impact on there overall fuel economy. As far as I am concerned, they can believe what they want to believe. I just want to let those people know that there are a few bridges out here in the San Francisco Bay Area that I would like to sell them. In reality, the amount of time you sit idling in your driveway, sit at a red light or drive in heavy traffic has a greater impact on your fuel mileage that the viscosity rating of your motor oil. The best oil to use in your car is the one specified by the manufacturer. |
Hey thank you so much guys. Those were some really insightful replies. Thanks so much for clearing everything about this issue.
5w-30 and 5w-20. This allows them to make the same stinking gas hogs that they always have and keep satisfying the government that gas mileage is increasing! Since the gas crunch of the 70's American auto makers have not done much to get public in more fuel efficient vehicles...it's called the Need for Greed! Here's one short article that deals with CAFE. Automobile and Light Truck Fuel Economy: The CAFE Standards -------------------------------------------------------------------------------- SUMMARY One of the least controversial provisions of the Energy Policy and Conservation Act of 1975 (P. L. 94-163) established corporate average fuel economy (CAFE) standards for new passenger cars. As oil prices rose, there was little expectation that manufacturers would have any difficulty complying with the standards. However, oil prices softened and the demand for small cars diminished. In response to petitions from manufacturers facing stiff civil penalties for noncompliance, the National Highway Traffic Safety Administration (NHTSA) relaxed the standard for model years 1986-1989. The current standard is 27.5 mpg for passenger automobiles and 20.7 mpg for light trucks, a classification that also includes sport utility vehicles (SUVs). An attempt in the 102 nd Congress to raise CAFE proved too controversial and was dropped from omnibus energy policy legislation before it could pass (Energy Policy Act of 1992, P. L. 102-486). The Clinton Administration supported greater fuel efficiency, but indicated in 1993 that an increase in the CAFE standards was not the option likeliest to be embraced first. In 1994, the National Highway Traffic Safety Administration (NHTSA) issued a notice of proposed rulemaking to explore raising the CAFE standard for light-duty trucks. Congress included language in the FY1996-FY2001 DOT Appropriations (P. L. 104-50, P. L. 104-205, P. L. 105-66, P. L. 106- 69, and P. L. 106-346) prohibiting the use of appropriated funds for any rulemaking on CAFE, effectively freezing the standards. However, the Senate conferees to the FY2001 appropriations insisted upon a study of CAFE by the National Academy of Sciences (NAS). That study, released on July 30, 2001, concluded that it was possible to achieve a more than 40% improvement in light truck and SUV fuel economy over a 10-15 year period at costs that would be recoverable over the lifetime of ownership. There are sharp differences in the CAFE provisions between the House and Senate versions of comprehensive energy legislation, H. R. 4. On July 12, 2001, the House Subcommittee on Energy and Air Quality adopted an amendment in markup to H. R. 2587 that called for a reduction of 5 billion gallons in light-duty truck fuel consumption over the period of model years (MYs) 2004-2010. This proposal came to the House floor on August 1, 2001 as part of H. R. 4. An amendment to establish a combined passenger car and truck CAFE of 27.5 mpg by MY2007 was defeated 160-269. The NAS study, released two days earlier, figured prominently in the debate. The Senate began debate on comprehensive energy legislation at the end of February 2002. Senators Kerry and McCain reached a compromise to propose a combined fleetwide average of 36 mpg by MY2015. However, on March 13, 2002, the Senate voted (62-38) for an amendment to charge NHTSA with devel-opment of new CAFE standards. The Senate then approved an amendment (56-44) to freeze "pickup trucks" at the current light truck standard of 20.7 mpg. The Senate passed its energy bill April 25 (88-11). On September 19, the conferees agreed to the House-passed goal of saving 5 billion gallons, but shifted the window to MY2006-MY2012. [See also CRS Report RL31427 for a side-by-side comparison]. MOST RECENT DEVELOPMENTS There are sharp differences in the Corporate Average Fuel Economy Standard (CAFE) provisions between the House and Senate versions of comprehensive energy legislation, H. R. 4. The House bill, passed on August 1, 2001, includes a provision calling for a reduction of 5 billion gallons in light-duty truck fuel consumption over the period of model years (MYs) 2004-2010. The provision would also require National Highway Traffic Safety Administration (NHTSA) to develop a weight-based system for establishing fuel-efficiency standards. The Senate began debate on comprehensive energy legislation at the end of February 2002. Senators Kerry and McCain reached a compromise to propose a combined fleetwide average of 36 mpg by MY2015. However, on March 13, 2002, the Senate voted (62-38) for an amendment offered by Senators Levin and Bond to charge NHTSA with development of new CAFE standards. The Senate went on to approve an amendment (56-44) from Senator Miller to freeze "pickup trucks" (to be defined by the Secretary of Transportation) at the current light truck standard of 20.7 mpg. This language was in the final version of the Senate energy bill when it passed April 25, 2002 (88-11). On September 19, the conferees agreed to the House-passed goal of achieving 5 billion gallons, but shifted the window to MY2006-MY2012. BACKGROUND AND ANALYSIS The Arab oil embargo of 1973-1974 and the tripling in the price of crude oil brought into sharp focus the fuel inefficiency of U. S. automobiles. New car fleet fuel economy had declined from 14.8 miles per gallon (mpg) in model year 1967 to 12.9 mpg in 1974. In the search for ways to reduce dependence on imported oil, automobiles were an obvious target. The Energy Policy and Conservation Act (P. L. 94-163) established corporate average fuel economy (CAFE) standards for passenger cars for model years 1978-1980 and 1985 and thereafter. The CAFE standards called for essentially a doubling in new car fleet fuel economy, establishing a standard of 18 mpg in model year (MY) 1978 and rising to 27.5 by MY1985. (Interim standards for model years 1981-1984 were announced by the Secretary of Transportation in June of 1977.) EPCA also established fuel economy standards for light duty trucks, beginning at 17.2 mpg in MY1979, and currently 20.7 mpg. Compliance with the standards is measured by calculating a sales-weighted mean of the fuel economies of a given manufacturer's product line, with domestically produced and imported vehicles measured separately. As originally enacted, the penalty for non-compliance was $5 for every 0.1 mpg below the standard, multiplied by the number of cars in the manufacturer's new car fleet for that year. Civil penalties collected from 1983-1998 totaled roughly $475 million. When oil prices rose sharply in the early 1980s, smaller cars were selling well, and it was expected that manufacturers would have no difficulty complying with the standards. However, oil prices had declined by 1985. Sales of smaller cars tapered off as consumers began to place less value on fuel economy and gasoline cost as an input in the overall costs of vehicle ownership. In response to petitions from manufacturers facing stiff civil penalties for noncompliance, the National Highway Traffic Safety Administration (NHTSA) relaxed the standard for model years 1986-1989, but it was restored to 27.5 in MY1990. The Persian Gulf War in 1990 caused a brief spike in oil prices, but it also demonstrated that it was unlikely that the United States or many of the producing nations would tolerate a prolonged disruption in international petroleum commerce. As a consequence, U. S. dependence upon imported petroleum, from a policy perspective, was considered less of a vulnerability. It was also becoming apparent that reducing U. S. dependence on imported oil would be extremely difficult without imposing a large price increase on gasoline, or restricting consumer choice in passenger vehicles. Many argued that the impacts of such actions upon the economy or the automotive industry would be unacceptable. Meanwhile, gasoline consumption, which fell to 6.5 million barrels per day (mbd) in 1982, averaged nearly 8.4 mbd in 1999, and has been peaking at roughly 9.0 mbd during the summer of 2002. There were highly controversial attempts to significantly raise the CAFE standards on passenger cars in the early 1990s. One proposal included in omnibus energy legislation was so controversial that it contributed to the Senate's inability in 1991 to bring the bill up for debate on the floor. NHTSA typically established truck CAFE standards 18 months prior to the beginning of each model year, as EPCA allows. However, such a narrow window permitted NHTSA to do little more than ratify manufacturers' projections for the model year in question. In April 1994, the agency proposed to abandon this practice and issued an Advance Notice of Proposed Rulemaking inviting comment on what level that standards might be established for trucks for MY1998-MY2006. The following year, however, after a change in congressional leadership, Congress included language in the FY1996 Department of Transportation Appropriations to prohibit expenditures for any rulemaking that would make any adjustment to the CAFE standards. Identical language was included in the appropriations and spending bills for FY1997-FY2000. An effort to pass a sense of the Senate amendment that conferees on the FY2000 DOT Appropriations should not agree to the House-passed rider for FY2000 was defeated in the Senate on September 15, 1999 (55-40). The rider also appeared in the FY2001 DOT Appropriations (H. R. 4475) approved by the House Committee on Appropriations May 16, 2000, and approved by the House May 19, 2000. However, as is detailed later, the conferees reached a compromise to drop it. Refocusing on Fuel Economy: SUVs, OPEC, and Kyoto Recent developments have focused fresh attention on the CAFE standards and fuel economy in general. The sharp increase in crude oil and gasoline prices that began in 1999 has brought into higher relief the continuing loss of market share of passenger cars to the larger, multipurpose sport utility vehicles (SUVs) that are subject to the less stringent light-truck fuel economy standard. A 1996 study conducted for the Department of Transportation found that consumers valued the larger vehicles for their versatility and roominess, and the availability of four-wheel drive. The increasing market share of these vehicles, combined with their lower average fuel economy, has contributed to a lowering in overall average fuel economy since the mid-1980s. Other pressures have had less to do with energy security and more to do with environmental objectives. The Kyoto Agreement would have required the United States to achieve a 7% reduction from1990 levels of carbon dioxide emissions, which implied a significant reduction in gasoline consumption, among other elements. Preferring to forestall any state or federal regulation, General Motors, Ford, Chrysler and Toyota announced on February 4, 1998, that they would produce cars in MY1999 with engine and catalytic converter technologies that would achieve lower emissions. In early November 1998, the California Air Resources Board (CARB) voted to reclassify SUVs 8500 pounds or less as passenger cars and hold those vehicles to California emission standards beginning in MY2004. Ford Motor announced in late July 2000 that it would improve the fuel economy of its SUV model line by 25% over a five-year period. Other manufacturers echoed similar intentions. During the Clinton Administration, the Congress was chary of committing the United States to the Kyoto Agreement, pending further decisions about the participation of developing nations, and how the agreement would be enforced. However, on March 27, 2001, Environmental Protection Agency Administrator Christine Todd Whitman indicated that the Bush Administration had "no interest" in any further negotiations on implementing the Kyoto Protocol. On February 14, 2002, the President proposed his own plan to reduce the growth in emissions. CAFE in Congress (1994-2000): Freezing the Standard Months prior to the midterm elections in 1994, NHTSA published a notice of possible adjustment to the fuel economy standards for trucks before the end of the decade. The following year, however, the House-passed version of H. R. 2002, the FY1996 Department of Transportation Appropriation, prohibited the use of appropriated funds to promulgate any CAFE rules; the Senate version did not include the language, but it was restored in conference. The House and Senate approved the conference report, and the bill became law (P. L. 104-50) on Nov. 15, 1995. Much the same scenario occurred in the second session of the 104 th and the first session of the 105 th : A similar rider was passed by the House and not by the Senate, but included by the conferees and enacted. This scenario occurred again in the second session. The prohibition was included in the version of the FY1999 appropriations passed by the House (H. R. 4328) in July 1998, but not in the Senate version (S. 2307); it was finally included in the omnibus spending bill at the end of the 105 th Congress (P. L. 105-277). The prohibition was reported from the House Appropriations Committee in the FY2000 DOT Appropriations (H. R. 2084) and passed by the House on June 23, 1999. However, the growth in gasoline consumption and the size of the light-duty truck fleet were concerns cited behind introduction in the Senate of an amendment to the bill expressing the sense of the Senate that the conferees should not agree to the House-passed rider for FY2000. The amendment, sponsored by Senators Gorton and Feinstein was defeated in the Senate on September 15, 1999 (55-40) and the prohibition was once again enacted into law (P. L. 106- 69). On May 16, 2000, the House Committee on Appropriations voted to include the rider in the FY2001 DOT Appropriations (H. R. 4475). An effort to strip the language was expected when the bill reached the House floor; however, there was none, and the bill, with the rider, passed the House on May 19, 2000 (395-13). Following its passage in the Senate, Senator Gorton introduced a motion to instruct the Senate conferees to not accept the House rider. After debate, the motion was altered to instruct the conferees to accept the House rider in return for agreement to authorize a study by the National Academy of Sciences (NAS), in conjunction with DOT, "to recommend, but not to promulgate without approval by a Joint Resolution of Congress, appropriate corporate average fuel efficiency standards." In addition to the factors required by statute to be weighed in determining maximum feasible CAFE levels, the motion was to require the study to consider the impacts of any proposed CAFE standard on vehicle safety and on effects on employment in the automotive sector and to analyze potentially disparate effects of revised standards across the sector. The motion was agreed to, followed by clarification, it applied only to the FY2001 appropriation. The conferees were successful, and the language was included in the appropriations bill signed into law on October 23, 2000 (P. L. 106-346). Legislation was introduced in the 104th Congress (H. R. 2200), the 105 th Congress (S. 286, H. R. 880), and the 106 th Congress (S. 147) that would freeze the current CAFE standards. Unlike the annual prohibition on rulemaking that has been included in the FY1996-FY2001 appropriations, these bills would have maintained the CAFE standards at the level in force at the time of enactment unless superseded by a subsequent act of Congress. None of these bills received further congressional attention. The Freeze Is Thawed: CAFE in the 107 th Congress A second summer of high gasoline prices, coupled with a heightened awareness that the nation is experiencing problems with many fuels and on many fronts, has built support for reconsideration of the CAFE standards in the 107 th Congress. For the first time since FY1996, the FY2001 House DOT appropriations did not include a rider prohibiting expenditures on CAFE rules, and legislation (H. R. 2587) reported out of committee in July 2001 that would require the automotive industry and NHTSA to achieve fuel savings. Past Role of CAFE Standards. The effectiveness of the CAFE standards themselves has been controversial. Since 1974, domestic new car fuel economy has roughly doubled; the fuel economy of imports has increased by roughly one-third. Some argue that these improvements would have happened as a consequence of rising oil prices during the 1970s and 1980s. Some studies suggest that the majority of the gains in passenger car fuel economy during the 1970s and 1980s were technical achievements, rather than the consequence of consumers' favoring smaller cars. Between 1976 and 1989, roughly 70% of the improvement in fuel economy was the result of weight reduction, improvements in transmissions and aerodynamics, wider use of front-wheel drive, and use of fuel-injection. The fact that overall passenger car fleet fuel economy remained comparatively flat during a period of declining real prices for gasoline also suggested that the CAFE regulations have contributed to placing some sort of floor under new-car fuel economy. General criticisms of raising the CAFE standards have been that, owing to the significant lead times manufacturers need to change model lines and because of the time needed for the vehicle fleet to turn over, increasing CAFE is a slow and inefficient means of achieving reductions in fuel consumption. Further, it is argued that the standards risk interfering with consumer choice and jeopardizing the health of a recovered domestic automotive industry. Opponents of raising CAFE usually cite fears that higher efficiency will likely be obtained by downsizing vehicle size and weight, raising concerns about safety. Proponents of a CAFE increase have argued that boosting the standards might bring about the introduction of technological improvements that do not compromise features that consumers value, but which would otherwise not be added because these improvements do add to the cost of a new vehicle. Growth of Light-Duty Trucks and SUVs. What has spurred a new focus on CAFE in the 107 th Congress is the growing percentage of the fleet made up of light-duty trucks and sport utility vehicles (SUVs), which are subject to a less stringent CAFE standard than are passenger automobiles. In 1988, light trucks constituted roughly 30% of the vehicle fleet. By 1994, this figure had grown to slightly more than 40% and reached an estimated 45% by 2000. The change is attributable to the burgeoning popularity of mini-vans and SUVs. The share of gasoline consumption by light duty trucks grew at an annual rate of 4.5% from 1985 to 1995 while automobile fuel consumption fell fractionally during the same period. (See also CRS Report RS20298, Sport Utility Vehicles, Mini-Vans and Light Trucks: An Overview of Fuel Economy and Emissions Standards.) On May 1, 2001, Senator Feinstein, joined by three co-sponsors, introduced S. 804. The legislation would raise the CAFE standard for light duty trucks and SUVs to 27.5 mpg – the same standard as for passenger automobiles – by MY2007. Applicability of the standards would also be raised from 8,500 pounds gross vehicle weight (GVW) to include vehicles up to 10,000 GVW. The legislation would also require that the fuel economy of new vehicles acquired by the federal government exceed the baseline for a particular vehicle class by 3 mpg at the end of FY2003, and 6 mpg by the end of FY2005. Once fully implemented and depending upon the growth in the size of the light truck fleet, it is possible that requiring these vehicles to meet the higher standard could save roughly 1.0 million barrels of oil daily. However, these savings could take nearly 20 years to fully capture; once the 27.5 standard were in effect for MY2007, it would still take an additional 10 years or more before the fleet of older, less efficient trucks and SUVs would be retired. On July 12, 2001, the House Subcommittee on Energy and Air Quality adopted an amendment in markup on an energy conservation bill (H. R. 2587) that calls for a reduction of 5 billion gallons in light-duty truck fuel consumption over the period of MYs 2004-2010. The provision would also require NHTSA to develop a weight-based system for establishing fuel-efficiency standards. The amendment, introduced by Chairman Barton and Representative Burr, passed by a vote of 29-3. An amendment by Representative Markey that would have established a CAFE of 37.5 for passenger cars and 29.0 mpg for light-duty trucks by MY2011 was withdrawn. Some members of the subcommittee criticized the provision that was adopted as saving very little fuel; however, Representative Dingell suggested that it was as stringent as he could support, and Chairman Barton emphasized the importance of achieving consensus within the committee on the language. The Chairman referred to the amendment as an "excellent first step." Critics of the proposal suggested it would require a relatively insignificant improvement in fuel efficiency to achieve these savings, with estimates ranging between 1-3 mpg over the period. The fuel economy provisions of H. R. 2587 were included in H. R. 4, debated by the House on August 1, 2001. An amendment to establish a combined CAFE fleet standard of 27.5 mpg by MY2007 was defeated, 160-269. The NAS study, released on July 30, 2001, was cited by opponents as well as supporters of the House proposal. The study concludes that it is possible to achieve a more than 40% improvement in light truck and SUV fuel economy over a 10-15 year period at costs that would be recoverable over the lifetime of ownership. The study does suggest that there may be safety consequences if manufacturers opt to meet higher standards by reduced vehicle weight. However, this position is disputed by some, who argue that heavier vehicles may be safer for their occupants, but may be responsible for fatalities when they strike lighter vehicles; and that a lightening of vehicles could reduce fatalities in certain incidents. The study also recommends that any redesign of the CAFE program include a program for trading fuel economy credits among manufacturers, and that CAFE standards should be based on vehicle "attributes," such as weight, rather than basing CAFE standards on whether a vehicle is a car or a truck. The congressionally mandated NAS study on fuel economy also recommends eliminating the CAFE credits that accrue to manufacturers of dual-fueled vehicles. These vehicles are rarely operated on anything but conventional gasoline, but allow their manufacturers to sell less efficient vehicles overall while still remaining in compliance with the CAFE requirements. Some estimate that the dual-fueled vehicle credit has resulted in an overall reduction of five-tenths to nine-tenths of a gallon in the average efficiency of vehicles sold. H. R. 4, as passed by the House, would extend the credit through MY2008. The bill also includes provisions requiring federal purchase of alternative-fueled vehicles and hybrids, and would require an additional study by the NAS on the "feasibility and effects" of reducing "by a significant percentage" fuel use by automobiles by MY2010. (The current NAS study may be read online at [http:// books. nap.edu/html/ cafe/].) In the wake of the terrorist attacks on September 11, 2001, Senate Republicans pressed the Democratic leadership to bring a Senate version of omnibus energy legislation to the floor as soon as possible, arguing for the soonest possible action on legislation that they asserted would enhance U. S. energy security. Debate on a revised version of a bill originally introduced by Senator Bingaman, S. 517, began in late February 2002. An amendment to that bill proposed to include the language of the National Fuel Savings and Security Act of 2002 (S. 1926) introduced on February 8, 2002, by Senator Kerry, the chair of the Senate Commerce Committee. Major provisions of this legislation relating to CAFE include: The Secretary of Transportation, in consultation with the Administrator of EPA, is to "prescribe" standards beginning MY2005 that would achieve a combined CAFE for passenger automobiles and light duty trucks of 35 mpg for MY2013. An interim standard would be established of 33.2 mpg for cars and 26.3 for light trucks, by MY2010. After MY2010, the Secretary would have the discretion to set a combined standard for cars and trucks. If standards are not established 18 months after passage, a series of default standards take effect, raising automobile CAFE to 38.3 mpg in MY2013 and light trucks to 32 mpg; there would be no combined standard. DOT would be required to review the difference between rated CAFE and in-use CAFE under "average driving conditions," with the objective of narrowing any differences to no more than 5% by MY2015. A system where manufacturers could trade credits for exceeding the standards between cars and trucks, and domestics and imports would be established. A special identifying label (Green Label Program) would be created for vehicles that both meet or exceed the CAFE standard and are also certified to have the lowest greenhouse gas emissions for vehicles in its class. A system of green stars would also be established to denote cars that exceed the standards, and a special gold star for cars exceeding 50 mph and light trucks exceeding 37 mpg. DOT would study "social marketing strategies" to acquaint the public to the meaning of these logos. Grants and awards would be provided for various competitions for technical demonstrations and innovation. A somewhat similar bill (S. 1923), introduced by Senator McCain, would delay the establishment of higher standards until MY2007, but would require a combined CAFE of 36 mpg by MY2016. It would introduce combined standards for cars and trucks in MY2007 and limit the credits that could be traded or purchased. This legislation would also eliminate the credit for dual-fueled vehicles. As debate on the Daschle amendment to S. 517 commenced in late February, it was reported that Senators McCain and Kerry had reached agreement to seek a combined CAFE of 36 mpg by MY2015. However, on March 13, 2002, the Senate voted (62-38) for an amendment offered by Senators Levin and Bond to charge NHTSA with development of new CAFE standards. The Senate went on to approve an amendment (56- 44) from Senator Miller to freeze "pickup trucks"– to be defined by the Secretary of Transportation – at the current light truck standard of 20.7 mpg. Proponents of the amendment argued that subjecting pickup trucks to higher CAFE standards would render these vehicles inadequately powered for farmers and laborers who use these vehicles to haul loads and perform work. Critics of the amendment pointed to the inconsistency of the Senate's maintaining, on the one hand, that the body lacked the expertise to set CAFE standards, but then turning around to freeze pickup trucks at 20.7 mpg. It is not apparent how "pickup trucks" was to be defined. If enacted, the provision could well result in a third category of vehicles, differentiated both from passenger automobiles, and the sort of SUVs and passenger vans that are currently categorized as "light duty trucks." Reaction in the hours after these votes focused upon the Levin amendment as a defeat for pro-CAFE forces – which it was, in a sense, although the resumption of a role for NHTSA in establishing fuel economy targets could be significant. However, the ramifications of the Miller amendment could prove a potent offset to NHTSA rulemakings, depending upon how much of the light truck fleet comes to be exempted from higher CAFE requirements. The Senate passed S. 517 (88-11) on April 25, 2002, substituting the bill's language for H. R. 4. Shortly before final passage, the Senate voted 57-42 to table an amendment offered by Senators Carper and Specter to require a reduction of 1 million b/ d (barrels/ day) in transportation sector fuel consumption. The amendment and its proposed reduction in fuel use was perceived by some as an arbitrary target and an indirect way of securing a significant increase in CAFE. Opponents argued that the Senate had already voted for NHTSA to conduct a rulemaking, and that the Senate had, in the Levin amendment, rejected setting specific targets, whether it be CAFE standards or specific reductions in fuel consumption. The conference committee instructed staff to see whether a compromise could be worked out by August 30, 2002. On September 19, the conferees agreed to the House-passed savings of 5 billion gallons in light-truck fuel consumption, but it shifted the applicable window to MY2006-MY2012. Both the House and Senate versions of the bill proposed to extend the CAFE credit to manufacturers of dual-fueled vehicles. The maximum annual credit of 1.2 mpg applies to vehicles manufactured through MY2008; that maximum drops to 0.9 mpg during MY2009-MY2012. A Senate-proposed list of expanded criteria to be taken into consideration in setting maximum feasible fuel economy levels was dropped. Also dropped was House language requiring a study of the "feasibility and effects" of reducing fuel use by automobiles "by a significant percentage." The Senate floor amendment capping "pickup truck" CAFE at 20.7 mpg also was not included in any of the House and Senate offers tendered to the conference committee. Conference Committee Chairman Tauzin, in response to criticism that the 5 billion gallon savings was negligible, pointed out that this target was a floor, not a ceiling, and that NHTSA could set future CAFE at levels that would achieve greater savings. Improving Fuel Economy: Other Policy Approaches Two possible approaches to reduce gasoline consumption involve (1) raising the price of gasoline through taxation, or other means, to a level that induces some conservation; and (2) increasing the efficiency of the automobile fleet in use. Of course, a combination of these two broad approaches can be used as well. Freedom CAR and the Partnership for a New Generation of Vehicles (PNGV)( 1993-2002). In late September 1993, President Clinton announced establishment of a government and industry research program, the Partnership for a New Generation of Vehicles (PNGV), that had among its goals development of an environmentally friendly "Supercar" that would achieve 80 mpg without sacrificing performance, affordability, and safety. The PNGV was an effort to combine the resources and expertise of federal agencies and laboratories with the private sector to reduce U. S. dependence on oil and maintain competitiveness without intervening to alter the market price of fuel. Research and development was to be focused on hybrid electric vehicles, direct-injection engines, fuel cells, and greater use of lightweight materials. Production prototypes of the Supercar were projected to be ready by 2004, a deadline that was appearing unlikely to be met. On January 9, 2002, the Bush Administration indicated that it would abandon the PNGV in favor of a new initiative to push for development of fuel cells. Research on fuel cells has been a focus of PNGV; of the $127 million provided to the program in FY2002, roughly $40 million was provided for fuel cell research and an additional $20 for hydrogen R& D. Although the Administration promises that the new initiative, called Freedom CAR, will be more aggressive, others expect it may largely operate along the lines of PNGV. However, where PNGV was directed by the Commerce Department, Freedom CAR will be administered by DOE. Price of Gasoline. Owing to higher taxation of gasoline in other nations, Americans enjoy one of the lowest prices for gasoline. As a consequence, the higher prices since 1999 – especially during the summer driving seasons – are experienced in the United States as a much greater increase, in percentage terms, than elsewhere. Past proposals to raise the price of gasoline to leverage consumers into more efficient vehicles have garnered little support. Owing to the relative price inelasticity of gasoline demand, many believe that the size of the price increase it would take to curb gasoline consumption to any degree would have a damaging effect on the economy of several times greater magnitude. Indeed, analysis of recent research (Plotkin, Greene, 1997, cited in References) suggested that an increase in gasoline taxes would be one-third as effective in achieving a reduction in demand as studies of the 1980s once projected. This is a significant reflection of the place that personal transportation and inexpensive gasoline has assumed in our economy and value system. Price, however, could be used to at least keep some floor under the cost of gasoline to motorists. For example, some argued during past episodes of high prices that, when prices softened again, the federal government should step in and capture the difference as a tax, and possibly devote the proceeds to developing public transportation infrastructure and incentives. This tax could be adjusted periodically to see that gasoline would not become less expensive than a certain level in real (inflation adjusted) dollars. Owing to the unpopularity of raising gasoline prices, raising the CAFE standard is more comfortable for some; however, it is a long-term response. Depending upon the magnitude of an increase in gasoline prices, no matter what the cause, a price-induced conservation response is nearly immediate and may grow as consumers initially drive less, and eventually seek out more efficient vehicles. CAFE and Reduction of Carbon Dioxide Emissions. Vehicles account for one-fifth of U. S. production of CO2 emissions. Some argue that raising the CAFE standards would be an ineffective or marginal way to reduce emissions of carbon dioxide. On one hand, improvements in fuel economy should enable the same vehicle to burn less fuel to travel a given distance. However, to the extent that technologies to improve fuel economy add cost to new vehicles, it has been argued that consumers will tend to retain older, less efficient cars longer. It has also been suggested that there is a correlation between improved fuel economy and an increase in miles driven and vehicle emissions. However, vehicle miles traveled have continued to increase in recent years when fuel economy improved only slightly, suggesting that the broader factor is the overall cost of driving, which is tied as well to the price of gasoline. The relationship between where people live and where they work is also a factor. The Clinton Administration proposed a five-year, $6.3 billion package of tax credits, and reliance on voluntary efforts by individuals and industry, to meet the proposed targets of the Kyoto agreement. Many believed that the Clinton Administration plan would fall well short, largely because carbon emissions are forecast by the Department of Energy to be 34% above 1990 levels by the year 2010. Some urged that Congress disapprove the treaty and sought renegotiation of the targets, arguing that meeting the proposed targets would require possibly crippling taxes and regulations. Others suggested that a significant increase in CAFE requirements would help meet the Kyoto targets and that an increase in CAFE should not wait final dispensation of the agreement. However, as noted earlier, the Bush Administration has removed the U. S. from the Kyoto process in favor of, for example, voluntary commitments on the part of industry. One interesting development is legislation enacted in July 2002 in California authorizing the California Air Resources Board (CARB) to establish regulations reducing greenhouse emissions from cars, light trucks and non-commercial vehicles. These would apply to MY2009 vehicles. The legislation, which makes California the first state to regulate carbon dioxide emissions, may be challenged. Though the legislation neither sets target reductions nor specifies how they are to be achieved, the assumption is that these reductions could only be achieved by higher efficiency. Consequently, the automobile industry argues that the law infringes on the authority of the federal government to set fuel economy standards. Historical Note on the CAFE Debate in the 102 nd Congress. As an historical note, legislation to boost the CAFE standards last received major attention in the 102nd Congress. One proposal (S. 279) would have abandoned uniform standards but otherwise left the historic infrastructure of the CAFE standards intact. Under S. 279, each manufacturer would have been required to achieve a 20% improvement in passenger car fuel economy by 1996 and 40% by 2001 over its 1988 baseline. The same standard of improvement would have been required of light trucks. In that same Congress, legislation was being developed to open up the Arctic National Wildlife Refuge (ANWR) for exploration. Proponents of higher CAFE standards predicted that there would be no support for exploration of ANWR without some increase in CAFE. S. 341, omnibus energy legislation reported from the Senate Committee on Energy and Natural Resources in May 1991, would have extended discretion to the Department of Transportation (DOT) to set "maximum feasible" CAFE targets for each manufacturer for MY1996 and MY2002. The DOT would have taken into account application of known fuel-saving technologies, MY1990 as a baseline for performance, sales mix, vehicle interior size, and safety standards. Credits earned could have been traded or held by the manufacturer. When it appeared that the ANWR provisions would almost certainly not survive unless the CAFE provisions were strengthened, Senator Johnston proposed an amendment in markup that would have had the effect of embracing the goals of S. 279, but over a longer time frame. The amendment was defeated in markup, as was an attempt to append to the omnibus bill the specific targets in S. 279. The proposal appeared to fail at the combined hands of those who either thought they went too far or not far enough. But the omnibus bill failed to reach the floor; a cloture vote on whether to proceed with it (it became S. 1220) was defeated Nov. 1, 1991. Both CAFE and ANWR provisions were stripped from modified legislation introduced in the second session of the 102 nd Congress. With the exception of the riders attached to the DOT Appropriations during the period of FY1996-FY2000, there has been no major legislative focus on CAFE until the 107 th Congress. CONGRESSIONAL HEARINGS, REPORTS, AND DOCUMENTS National Research Council. Committee on the Effectiveness and Impact of Corporate Average Fuel Economy Standards. Effectiveness and Impact of Corporate Average Fuel Economy (CAFE) Standards. Washington, D. C., National Academy Press, 2001. 166 p. National Research Council. Committee on Fuel Economy of Automobiles and Light Trucks. Automotive Fuel Economy: How Far Should We Go? Washington, D. C.: National Academy Press, 1992. 254 p. Plotkin, Steve. Greene, David. "Prospects for Improving the Fuel Economy of Light Duty Vehicles." Energy Policy, vol. 25, no. 14-15. December 1997. P. 1179-1188. U. S. Congress. House. Committee on Commerce. Implementation of Corporate Average Fuel Economy Standards. Hearing, 104 th Congress, 1st session. July 24, 1995. Washington, U. S. Govt. Print. Off., 1996. iii+ 59 p. U. S. Congress. House. Committee on Energy and Commerce. National Energy Policy: Conservation and Energy Efficiency. Hearing, 107st Congress, 1st session. June 22, 2001. Washington, U. S. Govt. Print. Off., 2001. iii + 137 p. U. S. Congress. Senate. Committee on Commerce, Science and Transportation. Motor Vehicle Fuel Efficiency Act. Hearing on S. 279. February 21, 1991. Washington, U. S. Govt., Print. Off., 1991. 175 p. S. Hrng. 102-19 —— Motor Vehicle Fuel Efficiency Act; Report to Accompany S. 279. (102nd Congress, 1st session. S. Rept. 102-48: 39 p.) —— Motor Vehicle Fuel Efficiency Act of 1990; Report on S. 1224. June 11, 1990. Washington, U. S. Govt. Print. Off., 1990. 29 p. (101st Congress, 2nd session. S. Rept. 101-329.) U. S. Congress. Senate. Committee on Commerce, Science and Transportation. Subcommittee on the Consumer. Motor Vehicle Fuel Efficiency Act of 1989. Hearing on S. 1224. 101st Congress, 1st session. September 7, 1989. Washington, U. S. Govt. Print. Off., 1989. 341 p. S. Hrng. 101-347 U. S. Congress. Senate. Committee on Energy and Natural Resources. Subcommittee on Energy Regulation and Conservation. Automobile Fuel Efficiency Standards. Hearing, 101st Congress, 1st session. April 4, 1989. Washington, U. S. Govt. Print. Off., 1989. 352 p. S. Hrng. 101-44 U. S. Department of Transportation. National Highway Traffic Safety Administration. Automotive Fuel Economy Program. Annual Update, Calendar Year 2000, appearing in full at: http://www.nhtsa. dot.gov/ cars/ problems/ studies/fuelecon/index. html U. S. Federal Register. Department of Transportation., National Highway Traffic Safety Administration. Light Truck Fuel Economy Standards, Model Years 1998-2006. Advance Notice of Proposed Rulemaking (ANPRM). Vol. 59, No. 66. Wednesday, April 6, 1994, p. 16324-16332. Department of Transportation. National Highway Traffic Safety Administration. Light Truck Average Fuel Economy Standard, Model Year 2004. Notice of Proposed Rulemaking. http://www.nhtsa. dot.gov/ cars/ rules/ rulings/ Cafe/LightTruck/NPRM-final. htm
Jack of all trades...Master of none! Could someone please fix my Instant Email Notification? Please get back to us with your fix! Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
I didn't read anything in that article about getting better gas mileage with 5w-30.
Where did you read this at? Why would they switch from 10w-30 to 5w-30 when the oil is the same weight when it is warm, therefore it would not affect anything on the engine? I would be interested on where this information you speak of comes from? |
CAFE Standards for automakers - A legislative decree developed by the same mental geniuses who mandated the use of MTBE in gasoline, causing an overall reduction in everyone's fuel mileage by 10%. These same mental geniuses proclaim to know better than all of us do how we all should live our lives.
I have heard it said that "Liberalism is a mental disorder" (Michael Savage, PhD, UC Berkeley ...about the only thing to come out of the "People's Republic of Berkeley" that makes sense.). Only the disordered mind would attempt to support an argument with reams of unrelated material. Then, I have also heard it said, too, "That if you dazzle them with brilliance, Baffle them the bull****". |
...oops! It looks like I go ahead of myself. The quote should be, "If you can't dazzle them with brilliance, baffle them with bull****".
Oh, yes, I know all about CAFE standards. I thought they were stupid 30 years ago and they are still stupid now. You see, the people who developed the CAFE standards continued to drive their Cadillacs and Lincoln Continentals, and would never let themselves be seen in public public either driving or riding in a Honda Civic. Even though former California Govenor Jerry "Moonbeam" Brown shunned the use of limosines during his 8-year term of office, his state vehicle of choice was a 1974 Plymouth Satellite, with 318 V8 that got 14 miles per gallon on "leaded" regular. You see, this car was pre-catalytic converter and he never even thought to upgrade to something cleaner burning. |
I've been listening to this CAFE stuff since the 70's and all it is, is another way for big companies to keep making big money. I get a kick out of Bill Ford wondering why his business is stagnent while he still produces all the BIG gas guzzling trucks like the Excursion! Now the EPA ratings are finally taking a hit...those were a farce too.
So, what CAFE amounts to is that:
If I am using 10W30 oil, I get 23MPG and if I use 5W30 oil, I get 23.00000000000000000001MPG Right? The amount of MPG you save with the CAFE standards is less than the amount of gas that drips out of the pump nozzles on the ground when you finish fueling. ^ I MEAN THAT ^.... ^It's TRUE^ Tom
If I knew what I did to break it, I would've known not to do what I did.www.classicwinnebago.com |
