Old 03-01-2006, 09:42 PM
Cloud Strife Cloud Strife is offline
Arrow Shocks of choice?
Well I need 4 new ones. They all fail the bounce test when the car is at rest. I oscillate when I hop off teh bumpers instead of a critical dampening response. This most likely explains why I can feel every tiny crack in the road and feels like I am gonna flip if I hit a big bump when I go offroading.
I have a 99 Blazer 4x4. I don't know if they shocks have ever been replaced but I just passed 124,000 miles so I am most likely due for a change.
There are many different types out there. Most seems to like Monroe reflex here while I have seen recommendations for Bilsteins.
I just need something similiar to stock as I do some mild offroading. Mud-holes, creek beds, hill climbing, etc. This is b/c I live in Appalachia......LOL
Thoughts plz ?
Old 03-01-2006, 10:11 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Shocks of choice?
Go to ebay and grab a set, I got a set of 4 for only 25 bucks and had them installed for $50.
They are awesome and are just as smooth as the expensive ones I removed.
Excellent handling and not too soft in the corners.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-01-2006, 10:37 PM
A set of what type or model would be very helpful.
Old 03-02-2006, 05:14 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
You get what you pay for . Off road shocks (in my opinion) should be much softer than handling/touring types so the tires can drop to the surface quickly on rough terain. I have Heckelthorn (not by choice ) , they came with my lift kit . But they ride great on and off road . White w/ red boots .
On another auto(jeep) I had monroe gas magnums and they seem to let the front end hop around a little excessive on potholes. I would not choose any store brands . Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 03-02-2006, 08:16 PM
DjEarth DjEarth is offline
I have a 99 LS 4x4
I just did all four with KYB Monomax Heavy Dutys and am very satisfied with the choice I made. No more bodyroll..it's created a very stable ride.
http://www.ajusa.com/cgi-bin/load?t=...c7fd542e1fea0a
Old 03-02-2006, 08:21 PM
I ended up buying Monroe Reflex from Rockauto.com
Old 03-05-2006, 08:39 PM
Items came in on Saturday. I am off to get an estimate on how much it will cost to have them installed.
Old 03-05-2006, 09:08 PM
BlazerLT's Avatar
AF -Advisor
Cost me CDN$100 for my install, anything more and you are being ripped.
BTW, that was from one of the most expensive shops around.
Don't allow them to bullshit you into thinking it is a big job seeing it is quite simple.
Old 03-07-2006, 09:15 AM
Mine ended up being 45 bucks for the install of all 4 of them.
Ride is a lot better but still a little stiff. Haven't taken them offroad yet but will this weekend.
Old 03-07-2006, 06:52 PM
BlazerLT's Avatar
AF -Advisor
Great!
Good shocks will be a little stiff when compared to the older worn out ones you had installed.
What you are feeling is normal.
Old 03-08-2006, 09:00 PM
93LT 93LT is offline
Originally Posted by DjEarth
I have a 99 LS 4x4
Thanks for the input on this particular shock. I've been eyeing them for awhile now, debating on them for the 95 LS. It has the soft ride suspension and worn out shocks. I don't particularly care for the soft ride suspension and plan on trying these shocks to see if it can firm the ride up and rid the vehicle of some of the vehicle body role.
Rod
1995 K1500 Ext. Cab Stepside
1997 Olds Bravada AWD
2001 Silverado LT 2500HD CC 4WD
2001 Yukon SLT 4WD
Old 03-09-2006, 07:34 AM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
How much of a pain to D I Y? I like to try and do anything that I can myself
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 03-09-2006, 08:07 AM
If you are mechanically inclined, they are not hard at all. If you live in areas where they salt the roads though, that could add to the PIA factor.
Rod
2001 Yukon SLT 4WD
Old 03-10-2006, 12:50 AM
Rmbodie's Avatar
Also , If I may add , Most likely you will want an air or electric impact wrench (like tire stores use) . Because the bolts are the locking type , they are difficult to turn .I think they are 18mm which I had to buy special for the job. The nuts on the bottom end rust over well and you have to fight it to get them off . I had to split one with a cutoff wheel and dremil tool to remove it on a 98 model . If you can get it done for $40 bucks , Pay them first and let them do it . I have all the heavy tools and it still took an hour on one troublesome bolt . Rob
2005 Grand Prix.
Old 03-10-2006, 07:34 AM
BlazinMlew's Avatar
OH yeah the salt is a plenty here. I havent had much problems with anything that is in alot of contact with the salt yet though. The wheel hubs came off fairly easy after a little convincing and the caliper bracket as well. It helps to have air tools to do things I found out. I might just have to try it.
