Old 03-01-2006, 08:53 PM
Jawboy Jawboy is offline
5 year sitting mustang
I have i 1986 mustang GT that i want to get running but has been sitting for about 5 years outside in oregon weather dont really know what i should do before i try starting it up any sujestions would be great
Old 03-01-2006, 11:06 PM
brokenantimatter brokenantimatter is offline
Re: 5 year sitting mustang
Change all the fluids out including gasoline
Change or atleast check the battery
Check the brakes they are probably rusted over
Inspect belts and hoses for rotting.
Old 03-02-2006, 02:07 AM
KimMG KimMG is offline
AF - Advisor
Just to add to the above list,
Check air intake for critters and to make sure nothing can't be sucked into the motor
May want to turn the motor by hand to be sure the rings aren't rusted in place
Old 03-02-2006, 11:30 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Yep, try it by hand first.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 03-02-2006, 03:37 PM
351wStang's Avatar
351wStang 351wStang is offline
Just a suggestion if the rings are rusted..an older man I know came across a '65 I think Galaxy. Car had a 390 in it and the rings where stuck. He worked all the spark plugs out and squirted the cylinders full of wd40. Let it sit over night and turned it by hand the next morning. Changed oil, gas, ect and she fired right up with new plugs, wires, and rotor button & cap.
1969 Cougar
357w & TKO - 475hp
Old 03-02-2006, 07:06 PM
if i cant turn pistons by hand what do u sujest
Old 03-02-2006, 08:34 PM
351wStang's Avatar
this
You are trying to turn the motor with a 1/2" breaker bar arent you?
1969 Cougar
357w & TKO - 475hp
Old 03-02-2006, 09:11 PM
i havent tried anything yet im just gathering information now
Old 03-02-2006, 10:23 PM
351wStang's Avatar
Just get a socket the will fit the crank bolt and a breaker bar or ratchet and start turnin that baby over.
1969 Cougar
357w & TKO - 475hp
Old 03-03-2006, 01:07 AM
alright thanks for the help man
