Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-01-2006, 08:48 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Fuel Pump Rewire?
Well, since everyone talks about rewiring their fuel pumps I guess I should follow suit. One thing is though, my car I guess has the 255 pump... But I don't know how to prove that, the whole back is tore up, like the carpet and the wood floor dealy thing.
I can't tell if anything is new, or been replaced, it looks like my fuel tank was taken off, but I can't tell, I have a 1G and I was wondering if there is a step by step process for rewiring the real/non-existant 255 on the 1g? I searched but found only bits and pieces. Thanks guys
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 03-01-2006, 09:11 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Fuel Pump Rewire?
http://www.vfaq.com/FAQlocator-fuel.html
DSM geek
Old 03-01-2006, 11:39 PM
MexRocket's Avatar
Thanks your my hero, But how do I determine the type of fuel pump?
Old 03-01-2006, 11:43 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Pull it out and check the part # weinus. Walbro makes replacement parts so don't think just because it's a walbro that it's a 255 or even 190...
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-01-2006, 11:48 PM
MexRocket's Avatar
Does rewiring really improve anything that much or is it just a good thing to do...
Old 03-01-2006, 11:53 PM
ez1286's Avatar
Yeah it does make a big difference, it's not that hard and it's cheap (I actually have most of the parts) it provides a more consistent power source to the fuel pump, like the up, down noise when the turn signal is on.
Old 03-01-2006, 11:55 PM
MexRocket's Avatar
cool, and good heads up on that 100 buck exhaust
Old 03-02-2006, 12:08 PM
kjewer1 kjewer1 is offline
AF - Advisor
To give a relatively recent personal experience, I rewired the stock pump in the EVO. With stock wiring and the voltage associated with it, it was mathematically good to ~35 lbs/min. At 34 lbs/min I would start to see the WBO2 pull away from the calculated AFR. So that was right on. According to the calculations it would be good for something like 44 lbs/min rewired. Sure enough, I have been as high as 43 lbs/min with WBO2 tracking calulated nicely.
Before the end of the season however I went to a 255, just because they are so cheap, and it's not as big of a strain on the stock EVO FPR since the stock EVO pump is roughly a 190. With large pumps I like the rewire not so much for the extra flow (but this is still a concern when you max out a 255 as I was and many others are these days) but for the extra current capacity. The 255s and Supra pumps etc can draw over 20 amps, not something I'm comfortable with on the weak stock wiring (18ga?).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
