Old 03-01-2006, 07:48 PM
Whumbachumba's Avatar
Whumbachumba Whumbachumba is offline
Cutting aluminum Need help ASAP
I need help, ASAP. I need to know how to cut a sheet of aluminum. It's for an English project and I don't know how to go about doing it. Thanks in advance.
Current Project: '70.5 Camaro; Air-Cooled GB: '66 Beetle; Shelby 427 Cobra
Old 03-01-2006, 07:53 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Cutting aluminum Need help ASAP
How thick?
-Mike
Old 03-01-2006, 07:57 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
aluminuim for an english project?
Seatbelts Saved My Life
.016x4x10
Yeah, we are working on the Toulmin model and advertisements. Our product is a candle holder, and the aluminum is for the base.
Old 03-01-2006, 08:04 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Tin snips. Get thee to the hardware store and get some tin snips. Should run you about $10 or so.
PHOTOBUCKET SUCKS
Old 03-01-2006, 08:24 PM
We have some tin snips around somewhere, but we can't find them. Any other suggestions?
Old 03-01-2006, 09:33 PM
MPWR's Avatar
Hmmm... I would recommend against a band saw, or also for that matter a chain saw. I suppose a cutting laser would work- but I expect tin snips would be a bit more practical.
PHOTOBUCKET SUCKS
Old 03-01-2006, 09:38 PM
drunken monkey's Avatar
Razor Sharp Twit
if the aluminium is not too thick and it's still in flat sheet form, then patience and a steady supply of stanley knife blades can give you a perfect straight cut. And a heavy ruler helps.
Old 03-01-2006, 09:46 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
You could stand on the ruler, too.
Old 03-01-2006, 10:06 PM
That probably still wouldn't be heavy enough. I'm a fairly light guy. Only 140lbs.
Old 03-01-2006, 10:14 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
jump on the ruler
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Feint Motion's Avatar
Feint Motion Feint Motion is offline
Plasma Cutter.
~Josh~
OldUser:IImportSupra
Do You Have a Car that Goez Sideways?
Old 03-01-2006, 10:48 PM
Originally Posted by Feint Motion
Plasma Cutter.
Yes, let me pull that one out of my ass.
Old 03-01-2006, 10:59 PM
evo8owner's Avatar
evo8owner evo8owner is offline
Send a message via AIM to evo8owner Send a message via Yahoo to evo8owner
One Of The Really Neat Things About Working As A Metal Fabricator Is
That I Get To "Play" With Some Very Cool Tools/Machines!
The One That You Need To Use Is A Sheetmetal Sheer.
Look In Your Local Yellowpages & Find a Sheetmetal/Fabrication Shop
Call A Few Up And Ask If They Will Cut It For You(If You Have The Aluminum Allready)
If You Still Need The Metal,See If They Have Any In The "Scrap Bin"
They Can Cut & Sell To You.
Or If You Can Wait A Few Days,
P/M Me Your Address And The Exact Specs And I'll Send You One
Hope This Helps,Jake
Old 03-01-2006, 11:23 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
does your school have a welding shop or auto class? someone there should be able to cut it for you. or lend you a tool to cut it.
