Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-01-2006, 03:14 PM
ImportBuilder's Avatar
ImportBuilder ImportBuilder is offline
Send a message via AIM to ImportBuilder Send a message via Yahoo to ImportBuilder
custom-built vs DC exhaust?
I'm buying a 95 Civic coupe soon, and I want to do a full exhaust system. Right now, it has just an aftermarket muffler. Here's my 1st question. I can build my own exhaust system for just the cost of tubing at school. My teacher charges $1/foot. I could do a full system, from the manifold to the muffler for probably $10-$12. I would run it using the stock routing, but avoiding as many bends as possible. Probably use 2.5 inch piping. Would this be a decent mod, or should I just save up and buy a decent custom exhaust?
Now Playing:
1x Pioneer DEH-3800MP HU
2x Majestic MCS650BC
2x Majestic MCS6923BC
4 AWG Power/Ground
1x Lightning Audio STRIKE S4.15.VC2
1x Lightning Audio STRIKE 24.500.1
Dynamat Xtreme in trunk
Coming Soon:
New SPL Setup
Old 03-01-2006, 03:50 PM
S13wanabe's Avatar
S13wanabe S13wanabe is offline
Re: custom-built vs DC exhaust?
As long as your bends are mandrell bends, do it yourself. Custom is the way to go. You can make your own test pipe too. If sound is a concern you can run two mufflers along the same pipe. Just make sure they are straight throw design.
Old 03-01-2006, 05:56 PM
cjcivic cjcivic is offline
i wouldnt do it custom. after i did my swap i got an apexi n1 muffler and a high flow cat. i had a local shop make me a custom exhaust out of that. the pipe is 2.5''. it sounds like shit and it is so loud. i went in thinking that a custom exhaust would be cheaper than buying a good greddy or apexi but i ended up spending about the same amount. go with the dc...you will be happy with your choice.
Old 03-01-2006, 06:18 PM
S13wanabe's Avatar
Of course yours sounded like shit, Apexi N1 muffler. Mine sounds mean as shit at wot, and is way quiet the rest of the time. I don't have a cat, and run two magnaflow straight thru mufflers. One is a resonator round type under the car, and the other is a stock looking unit on the end. They are both straight through so I'm not sacrificing any power by using two. I have 2.5 inch piping and my total spent was about $250.
Old 03-01-2006, 06:52 PM
how much did u pay for ur mufflers?
Old 03-02-2006, 02:13 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
If you go custom, don't go bigger than 2.25" for NA (2.5+ is okay for turbo). Just think about it this way... there aren't many bends on a civic to begin with so you won't have to worry much about restriction. What you should do is spend the money and get a hi-flow cat. Bolt it up and put a resonator right after it or if your linkage is in the way, put it back further behind the linkage but prior to the bend toward the rear trailing arm. All you'll need is one resonator even with a fart can. If you plan on staying NA, you may want to invest in a header first, then add the rest onto it after...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 03-02-2006, 03:38 PM
S13wanabe's Avatar
Good advice above. My motor is fully built NA so 2.5 inch was what I needed. I got both mufflers for about $80. Keep in mind I do get a discount. The exhaust work was about $150.
Old 03-02-2006, 04:28 PM
The car doesn't haev a cat. It never did, apparently. It is pretty loud right now, but as far as I know, my friend has nothing between the manifold and muffler. Will I need to buy a cat to pass emmisions? I live in Arizona, and the car is a 95 with an engine swap. I think it's a 1.5L engine, with an intake manifold from a bigger Honda engine.
Now Playing:
4 AWG Power/Ground
Coming Soon:
New SPL Setup
