Go Back   Automotive Forums Car Chat > Cadillac > Eldorado
Old 06-30-2002, 12:05 AM
butch butch is offline
Lightbulb 1992 cadillac overheating help
I am having a problem locating what the problem is with my car, it overheated, so i changed the radiator and then thought the censor had gone bad, but it is still overheating any suggestions
Old 07-08-2002, 05:25 PM
overlander64 overlander64 is offline
1992 Cadillac Overheating Help
While my Cadillac is a bit older, this may apply to your later model as well. With my '75, the exhaust heat riser valve becomes termperamental nearly every spring. If this valve is not freed-up, the car overheats whenever it is driven for extended periods of time - - it also has been know to cause the brake fluid to boil in the master cylinder.
1975 Eldorado Convertible
1984 Eldorado Biarritz Convertible
Old 07-02-2003, 11:19 PM
tdnyc tdnyc is offline
First, make sure theres anitfreeze in it. If so then it could be a broken line or hose. And if thats not it, it could be the headgasket.
Old 01-24-2004, 04:36 PM
TONYW1943 TONYW1943 is offline
Overheating Cad
I HAVE OWNED CADs SINCE 85 FOR MODELS 85 TO 93 IF IT OVERHEATED ONCE AND GOT REAL HOT. MY ADVICE GET RID OF IT, IT WILL NEVER BE RIGHT. I HAD THIS TO HAPPEN TWICE AND NEVER COULD GET IT FIXED.
