Old 06-30-2002, 12:01 AM
Phat_Si's Avatar
Phat_Si Phat_Si is offline
Send a message via AIM to Phat_Si
Code 8???
What is a code 8, and what's wrong with my car???
-----'89 Crx Si-----
I/E
NGK plug wires
Custom backseat
Rims
clear corners
Awia head unit w/Pioneer speakers
Blowin' Smoke!
--Soon To Be--
slammed
new D16a6 block
sohc vtec d16z6 head, P&P'ed
gude stage 2 cam
gude cam gear
some fuel goodies etc...
Old 06-30-2002, 12:58 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
a code 8 refers to the Top Dead Center timing of your car. find the specs for your car and adhust the timing back into spec.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-30-2002, 08:07 PM
Phat_Si's Avatar
ok, it might have been a code 18 so whats that???
I/E
NGK plug wires
Custom backseat
Rims
clear corners
Blowin' Smoke!
--Soon To Be--
slammed
new D16a6 block
gude stage 2 cam
gude cam gear
Old 06-30-2002, 08:33 PM
88ReX 88ReX is offline
there's no code 18
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 06-30-2002, 11:35 PM
Phat_Si's Avatar
oh, ok. could the code 8 TDC thing make my car not start sometimes???
I/E
NGK plug wires
Custom backseat
Rims
clear corners
Blowin' Smoke!
--Soon To Be--
slammed
new D16a6 block
gude stage 2 cam
gude cam gear
Old 07-01-2002, 03:52 PM
crxlvr's Avatar
yes if the timing is too far off, then the valves will not open and close at the appropriate times, getting no air/fuel to the spark.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-01-2002, 05:54 PM
Shadowkahn Shadowkahn is offline
Send a message via ICQ to Shadowkahn Send a message via AIM to Shadowkahn
code 8 is top dead center SENSOR, not TDC. I bet if you take the cap off your distributor and look, the TDC sensor is cracked. I further bet your rotor isn't screwed in anymore. Sometimes the damn screw backs out and flies around in there and breaks stuff - - usually the TDC and/or crank angle sensors. Unfortunately you can't get those parts individually and will have to replace the entire distributor sub assembly, which will run you roughly $250.
