Old 03-01-2006, 12:48 PM
Nu24rse Nu24rse is offline
Angry '89 Camero trouble starting 2nd time
Hello, I have a 1989 camero V8 305, the camero starts fine the 1st time I start it. I will come back, say 1 hour later, and it has the hardest time starting, and this is getting worse everyday. I have to hit the gas and get the engine rpms up to get it to stay started.
Also, if I have to sit in one place for more then 10 mintues, the temperature gauge goes up to at least 220, then I will get going again, and the temperature goes back down.
Does anyone know what could be wrong with my car? I am new at this, so I need details, ok.
Thanks so much for your time,
Candice
Old 03-01-2006, 02:11 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: '89 Camero trouble starting 2nd time
The temp is normal, Camaros are desinged to run at 220, the fans don't even come until past that. You could make sure the air dam (black plastic piece sticking out from under the radiator is still there and in one piece. But Camaros '82 - '92 do run a bit hot.
As for the starting issue, when was the last time your Camaro has seen a tune up?
Old 03-02-2006, 02:56 AM
malletslinger's Avatar
malletslinger malletslinger is offline
I agree with wright...your camaro just needs some sweet lovin
Try to be a bit more compassionate with her...make her feel young again...lol
Old 03-09-2006, 01:26 AM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
Yea, give it a tune up first. Has the car ever overheated? If it has you need to replace that thermostat, it may be sticking. Even though they do tend to run warm, its cheaper to replace a thermostat then a piston. If the car still gives you problems starting it could be VAT's or maybe even an ignition switch. You could possbily even have a fuel pump losing life. This is a lot for a newbie...give it a tune up and come back lol.
