Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 03-01-2006, 01:39 PM
milk123 milk123 is offline
93 sonoma fuel trouble
It just shut off going down the road. The fuel pump is not cutting in. I put another source of power to the fuel pump and the pump started pumping but the truck won't start. I put gas down the trottle body and it runs on the prime but that's it. What do you guys think I should try to get this truck going. Thanks
Old 03-01-2006, 03:35 PM
Re: 93 sonoma fuel trouble
If it were the relay , should it have started when I used the external 12 volt supply to power up the pump. I took off the filter and made sure that the fuel was passing through it. It's a 4.3 engine.
Old 03-04-2006, 05:25 PM
What exactly is this forum for.. You'd get more info from a deaf mute.
Old 03-04-2006, 11:10 PM
Prandtl Prandtl is offline
To me, it sounds like the fuel pump is bad. The diaphram inside may have stopped working properly even though the pump is on........
