Old 03-01-2006, 10:47 AM
chgoguy74 chgoguy74 is offline
Send a message via AIM to chgoguy74
What to do with rad flush waste?
As tempting as it is to take a leisurely stroll to the sewer drain in my backyard, I can only assume it would be a bad thing...
Does Murray's or other parts stores take that stuff? What do you transport it in? About how much should I expect to have... 5 gallons, 10 gallons, a teaspoon?
Should the car be level when draining, or is it OK to jack up the front? or should you jack up the back to make everything drain out the front?
thanks for your help...
Old 03-01-2006, 11:34 AM
Teal95Jimmy's Avatar
Teal95Jimmy Teal95Jimmy is offline
Send a message via AIM to Teal95Jimmy
Re: What to do with rad flush waste?
I don't know about auto parts stores taking back used coolant and such, but a lot of recycling centers and land fills will take used oil and coolant at almost any size (not like shop amounts but home do it yourself amounts).
Old 03-01-2006, 12:49 PM
billibong's Avatar
billibong billibong is offline
Once you do the initial drain you should have about 1.5 to 2 gallons of used antifreeze. Most local landfills have a recycling are that will accept used hazardous waste, such as oil and glycol products. The best thing is to just put them into plastic containers, either what the replacement came in or gallon milk jugs, and take them in.
You DO NOT want to dump it in the backyard. Other than the hazards to animal life in the area, leaching of the product into the aquifer (water table) and other environmental hazards, there is also the problem of the EPA, State, Commonwealth or Provincial Environmental Agency or other governing body - or nosy neighbor - turning you in and making you pay fines.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 03-01-2006, 01:13 PM
2kTrailBlazer's Avatar
2kTrailBlazer 2kTrailBlazer is offline
Send a message via AIM to 2kTrailBlazer
I have heard of some parts stores taking old coolant, If you only have a gallon or two try your local auto shops, they may help you out too .
Old 03-01-2006, 01:23 PM
What about the position of the car? Does it need to be level, leaning forward, leaning back?
Old 03-01-2006, 02:28 PM
billibong's Avatar
When you drain from the radiator it should be level. If you drain from the engine block plug, you can have it level or on a slight incline.
The safest way to work on your truck is with it level, so that is what I would suggest.
There are numerous threads about cooling system maintenance, and I believe one of them is in the FAQ section, so you might want to read through them.
Good luck.
billibong
Repairs:
