Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-01-2006, 09:59 AM
adidas_boi adidas_boi is offline
Just got it & third gear grinds can u guys help???
97' Eclipse GSX 5-speed w/ only 68k. Third gear grinds like every other time I shift into it. Only had the car for under 500 miles. In the mourning it seems ok, but after driving it for like 15 minutes (or till the engine gets to normal temp) it starts grinding. As of the moment I try to avoid using third gear. I'm planning on changing the tranny fluid and rear tranny fluid this week, but I don't think that's the problem. It's also got a fidinza flywheel and act stage 2 clutch installed. There's also a clutch fluid leak some where, and I fill it up at least twice a week. I'll be checking that this week as well. Can I just get third gear replaced? Do I need a new tranny? Any suggestions??? Any help would be greatly appreciated.
Old 03-01-2006, 10:25 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Just got it & third gear grinds can u guys help???
Before going and replacing your tranny, which would be really expensive, you should change your tranny fluid and put Penzoil Syncromesh in it. That has solved so many peoples problems with third gear. If it doesn't help though, you can have just third gear replaced but its a terrible pain in the ass to pull the tranny out of an AWD car. If your gonna go and do that and have big plans for your car, then I would suggest building up your tranny a bit too.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 03-01-2006, 05:57 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Also seeing that you have a leak. Check your clutch cylinders.
1991 GSX 2.3 Stroker
Old 03-01-2006, 08:39 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Leak=air in the line=clutch drag. Is it just 3rd gear? Sounds like you have a bad blocker ring, $3 part $300+ in labor lol
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 03-01-2006, 09:53 PM
Thanks for your input guys. I'm changing the tranny fluid w/ pennzoil syncromesh this weekend and try to fix the clutch fluid leak. I'll update you guys on the progress. Thanks again!
