Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-01-2006, 07:30 AM
guidorr73 guidorr73 is offline
Speedo screwed
Hey guys,
I have a 92 talon fwd nt 5spd 2.0 dohc. Problem is the speedometer stopped working. I pulled the speedo cable connector off of the tranny and spun the cable and the meter does move. I drove with the instrument cluster out and cable reconnected and no movement on the cable. Sounds like it is in the tranny. Anybody run across this before? Tranny was rebuilt last year for $800 but it is out of warrantee. Any easy fix? Thanks
Old 03-01-2006, 09:37 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Speedo screwed
Sounds to me like your vehicle speed sensor is broke. As far as I know, its within the tranny and you have to pull the tranny just to replace it. Definetly not gonna be an easy fix for ya.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-01-2006, 10:24 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Speedo screwed
The speedo sensor should sit right on top of the tranny. You'll have to take out the battery and all the stuff on that side. There's no sensors "inside" the tranny. It's one of the only sensors on the tranny. But it sits on the very top.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-01-2006, 10:30 AM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Re: Speedo screwed
Actually, what david says is true but it is not the speed sensor. He stated above that when he spun the shaft on the sensor and that the needle moved. THIS EXACT SAME THING HAPPENED TO ME! My problem was that there was no plastic gear on the shaft, but when I bought that piece, I found out that the gear inside the tranny was missing. (The plastic gear that i just bought now had nothing to attach to it).
SO your problem is the gear that should be in the tranny, which most likely broke off. So your solution would have to be to drop the tranny.
I just lived with the problem.
Old 03-01-2006, 10:48 AM
Re: Speedo screwed
How do you take it out? Does it thread into the tranny or something?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-01-2006, 10:49 AM
Re: Speedo screwed
Thanks for the input folks. I hate it when reality sets in. I'll probably wait untill it is warmer before I take it further. Question, if the gears broke off, is there a chance of doing more damage to the tranny with the parts floating around in there? It is driving fine right now. Btw, very quick reply. Thanks again.
Old 03-01-2006, 12:04 PM
Re: Speedo screwed
Well thats the thing....I would assume that the gear that broke off is plastic, and that it would just grind up with the spinning gears (which isnt good, lol) but I never heard anything strange come from my tranny. I would just say either live with the problem or drop the tranny and inspect.
But are you sure that your 92 has a speed SENSOR? i remeber reading on dsmtuners that the early 90's run off of a cable. Look into that before you drop the tranny!
Old 03-01-2006, 12:12 PM
Re: Speedo screwed
It is definately a cable. I looked in the chiltons manual for my car and tranny. No sensor involved. It looks like I can pull the gear and shaft assembly through the top of the tranny. It said that there is a hold down screw that needs to be removed and it just sits in the housing. I haven't found the screw yet but I didn't look very hard. I will try to pull it out, but like you say, if the gear that drives the assembly is shot, it won't help much.
Old 03-01-2006, 02:43 PM
Re: Speedo screwed
Right the bolt that holds the gear in place should be a 10 mm bolt (it was on my 97 atleast)
GL
