Old 03-01-2006, 07:10 AM
LS19962DRBLAZER4X4 LS19962DRBLAZER4X4 is offline
Exclamation Replacing Spring Leafs after 10 Years....
I have owned my Chevy 96 4x4 2drS-10 Blazer now for over 10 years. The truck had a suspension package that included a tow hitch. I have replaced
all four shocks during the 10 year period. I was told the leaf springs
have to be replaced. I never thought these where made shoddy. I have
4 Eldenbrock shocks that replaced the older 70000 mile shocks, yet
when I drive over a bump it feels like I hit a 3 foot speed bump.
( It's more common during winter driving)...
I always thought they put Bilsteins on all 4x4 blazers in the mid 1990's..
If anyone else has these problems send me a email or message...
Thanks..
Old 03-01-2006, 11:53 AM
Moser97 Moser97 is offline
Re: Replacing Spring Leafs after 10 Years....
Sorry I can't offer much help. I have similar problems with a 99 Jimmy. Look at the post "99 Jimmy ... rough rider" from a couple days ago on this forum. I am going to check out the suspension parts suggested Saturday AM, but I am thinking about springs too. Hopefully someone can add a little more to the mix for us to consider.
'06 Honda Accord
'02 Chevy Tracker SS - only SS you'll see, 2L, 5 speed
'97 Ram 1500, 5.2, 2wd, 46RE
Old 03-01-2006, 12:02 PM
Cloud Strife Cloud Strife is offline
I am in the same boat so I am following this thread closely.
Old 03-01-2006, 12:42 PM
billibong's Avatar
billibong billibong is offline
You might want to try helper springs. They attach to the top of your existing springs, and "help" control the ride a little bit. Usually they are used if you are going to be towing, but they may help your problem.
The other thing is it may be the shocks. I believe that all the blazers came with bilstiens from the factory, a very good shock. You may want to check to see if your shocks are leaking, or if they just aren't designed to support a 4X4.
I haven't heard to often of leaf springs failing, unless the vehicle is older than yours or the shackles holding the springs have failed in high salt areas or from some other cause.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 03-01-2006, 11:28 PM
SBlazerNCS SBlazerNCS is offline
I agree with billibong. The first gens have terrible leaf spring sag after a few years, i havent noticed on the second gens. Even so, thats not the same as failure.
Add a leafs might help as well.
Old 03-02-2006, 05:03 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
My dad had this problem , NEW shocks were installed , and any bump even the reflectors would make a harsh thud impact sound . Turns out a mechanic of 10 years installed one shock upside down . Turned it over and all was well .
I installed helper spring kit , The Half spring style that you don't have to take the axle apart . It worked great and you could actually increase the ride height too . I put them a K5 blazer front and back , and a jeep cherokee. they look like traction bars from behind too . Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 03-02-2006, 02:51 PM
OverBoardProject OverBoardProject is offline
Banned
I'm doing a related how to up, check back tonight or tomorrow.
Old 03-02-2006, 03:12 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
if you truck is jumping up like that, there is nothing wrong with your rear springs.
If the springs were shot going over a speed bump would feel like running over a warm stick of butter.
Check your rear sway bar end links and slow down going over speed bumps, they are there for a reason, if you are causing your truck to launch like that, it isn't the springs fault, it is the driver.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-02-2006, 05:20 PM
Banned
http://www.automotiveforums.com/vbul...16#post3876616
