Old 03-01-2006, 03:25 AM
GirlBear's Avatar
GirlBear GirlBear is offline
Bad Response
When I step on the gas to take off my truck stutters a bit. Kinda makes a sound like a deisel. Is it or could it be A filter? or injector?
http://jowulf.deviantart.com/
Old 03-01-2006, 03:27 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Bad Response
More like ayour MAF sensor needs cleaning.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-01-2006, 03:29 AM
GirlBear's Avatar
Re: Bad Response
oh yeah and a full take of gas recently only 160 miles. When I filled up it took 16.21 gallons figured 1.5 gallons in it. So say 18 gallons all together. WTF is going on......................
Old 03-01-2006, 03:31 AM
BlazerLT's Avatar
AF -Advisor
Re: Bad Response
Echo...echoo.. echo....
Old 03-01-2006, 03:37 AM
GirlBear's Avatar
Re: Bad Response
huh?
Old 03-01-2006, 06:31 AM
billibong's Avatar
billibong billibong is offline
Re: Bad Response
GB, When was the last time you did a tune up?? It could be a couple of things that a tune up will take care of.
I think that BLT is aying that you need to clean the MAF. It has been discussed numerous times on the forum. That is another possibility, when the Mass Air Flow sensor gets dirty it screws with the readings of how mucha air is flowing through the intake and adjusts the fuel flow based on erroneous, or bad, information. The cleaning is really easy, just be careful with the filaments, and use a soft brush and a cleaner that doesn't leave a residue - like a brake cleaner.
Another thing you might want to check is the throttle body, it could be sticking because of build up around the butterfly. A good cleaning with throttle body or carb cleaner and a soft brush will take care of that.
Let us know how it turns out.
bill
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 03-01-2006, 07:29 AM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
Re: Bad Response
I would say tune up as well.
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 03-01-2006, 10:06 AM
Ultrashock's Avatar
Ultrashock Ultrashock is offline
Re: Bad Response
GET A TUNE UP. I went from getting 11-12 miles per gallon to getting 16 miles per gallon in my Blazer. Its amazing how much it went up from just one tune up. The throttle response improved dramatically as well
92 S10 Blazer Sport
4.3l Vortec V6 (W)
275,000 miles
Jasper engine, Rebuilt tranny + rearend
04 Pontiac Grand Prix GT
43,000 miles
Old 03-01-2006, 02:42 PM
BlazerLT's Avatar
AF -Advisor
Re: Bad Response
I thought she kept this engine tip top shape though.
Old 03-01-2006, 09:42 PM
EJ21 EJ21 is offline
Re: Bad Response
I would say the MAF to..but you also want to change the fuel filter if you run the gas tank low...picks up alot of dirt in the filter. Also some dry gas might help to..I see snow on the ground and if you get alot of moisture in the tank from running below half..you could be adding water to your gas. Which could cause a misfire such as yours..hope it helps..Ej P/S are you saying your gas gage won't work? I know alot of problems the blazer have is bad Altenators..are you experiancing any electrical probs? I have heard the fuel pumps to go out alot in these to..my son has a 97 and has had 3 put in and they are not cheap. His new would cost about $350.00 and that is not installed. You have to drop the gas tank on those! He managed to get his from the junk yard for $150.00 and put it in himself. Good luck ..and I hope you solve it..let us know..k
Old 03-01-2006, 10:36 PM
GirlBear's Avatar
Re: Bad Response
I've been slippin. No good reasons to neglect my motor cept COLD-$$$-Time. Some one tossed out my electric heaters for my parents garage. But I'm in dire need of a tune up so I musn't procrastinate a second longer. I'm gettin over a sinus infection, Boogers every where.lol Really not lookin forward to doin the plugs tho. But it has to be done. Thnx GUYS!!!!!!!! Thinkin bout rippin the top of the motor apart and cleanin the Spider Assembly too. Intake was black like a chimney the other day. But again Time and My son's many Health issues may have me takin the blazer to a Garage(usually avoid like the plague).
Old 03-02-2006, 02:17 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Re: Bad Response
GB, Check your PM . When you did your intake gasket , did you have any sign of leakage in the nut kit area ? Do you have a washable air filter on it ? K&n ,etc.. The MAF may have oil coated on it . If so , As they described will read bad info . Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
