Old 03-01-2006, 12:47 AM
ATM_14 ATM_14 is offline
No lowend power after rebuild
Alright. So I got this '90 Civic EX from my neighbor with a blown head gasget. OK, no prob. Statred tearing it down, ended up having 3 cracked valves, 1 messed up piston, the rocker arm was warped, and the thrust bearings were worn flat on the crank. So, I did a full rebuild. Nothing special. Cleaned the whole damn thing, reboared the cylinders, put in basic oversized, rebuilt the head (actually had a pro do it, friend of mine) and in the end put it all back together. Just for info, all filters and hoses replaced. Started it up last week, sounds great! But, I have no lowend power. When I start going I need to rev it up to like 2800rpm or is just sputters on me. Same on hills, I'll be turning 3500 but it just drops as I go till I downshift and hold it over 4k. What kinda problem am i looking at?
Old 03-01-2006, 06:24 AM
Hybrid1990crx's Avatar
Re: No lowend power after rebuild
sounds like a valve timing issue.
Old 03-01-2006, 03:14 PM
sblkcamaro70 sblkcamaro70 is offline
yeah sounds like a timing issue
Old 03-01-2006, 03:34 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Just for my own piece of mind...this would mean his valves were not closing at the correct time and hes losing compression right? I know alot, and I've built engines...but mine come out right the first time! So this would be new to me as well.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-01-2006, 05:47 PM
OK, just fyi this is my first real rebuild that I've done. I know what you mean by timing but where should I look first to correct the problem? Would it be the timing belt is not on correctly or maybe the distributor isn't in the proper orientating w/ the cam.....where's a good place to start?
Old 03-01-2006, 06:59 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
check the timing marks on the crank pully and the cam gear...line up the crank with the TDC mark than make sure the cam gear marks are lined up with the cam TDC marks.
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 03-01-2006, 08:48 PM
what stupid said. ^^^^
Old 03-01-2006, 10:23 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
whats the leakdown readings?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 03-02-2006, 12:26 AM
Hey, thanks for all the help so far. OK, so I took a look at the timing belt, the crank has an obvious mark where it lines up to, and the cam should be pointing strainght up. If this all sounds right, then they are all alighned properly. Another question I had concens the sparks. I got a d16a6 and the specs say the sparks should be gapped at .042mm. The ones I got were gapped at .044. Is it worth gapping them to the spec. of will .002 no affect it?
And what is leakdown??
Old 03-02-2006, 01:36 PM
.002 ... that wont effect it.
check ignition timing with a light...
for a stock si...its like 16-18 advanced....i think
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
