Go Back   Automotive Forums Car Chat > Subaru > Forester
Old 02-28-2006, 11:54 PM
Eslhockey92g's Avatar
Eslhockey92g Eslhockey92g is offline
Overhead Clock stoped working
1999 Forester 4cyl manual
the overhead clock stoped working a while ago and i never really cared to much to fix it but now i do haha, the fuses are all fine. I'm not to sure the problem would be. any ideas?
Old 03-01-2006, 10:41 PM
drew.mather drew.mather is offline
Re: Overhead Clock stoped working
Had the same problem. You can pop it out of its shell and test the circuit feeding into the back of the clock module. The wires may be disconnected or faulty. If there isn't a problem with the wires, you probably just need a new clock module. I think I was quoted $36 at the dealer. It's easy to install yourself. hope that helps! Good luck! Drew
Old 03-26-2006, 11:24 AM
twoods1389 twoods1389 is offline
same happened to my 2001, i was told it would be $85 from the dealer for a new one so i just use my cell phone for the time, or just buy one of those $5 digital clocks from any hardware or pharmacy type of place
Old 12-30-2007, 12:18 PM
Mark Day Mark Day is offline
The overhead clocks in the Subaru Forester had problems with one surface mount resistor coming loose. The clock was actually working, but no display could be seen. The fix is to take the clock out, take it out of the case ( be carefull to do this over a paper so you can see what falls out if any thing).
One of the surface mount resistors just to the right of the display needs resoldered. Careful, I soldered it back in with normal soldering instead of the surface mount type of soldering (it will stay in place).
Good luck
If the resistor is lost, replacements can be purchased at Radio Shack or Digi key. ( it is the same value as others on the circuit board 3.9 ohms or 3.9K ohms, I can remember the exact value)
