My husband an I have recently bought a used 91 lumina an it was running till a day ago , when we try to start it , it dies we have checked everything an replaced the fuel filter any ideas on what else it could be ...any ideas would be very much appreciated
Re: 91 chevrolet lumina
Hit it with a blast of starting fluid sprayed in the intake, if it runs on that and dies, it's a fuel issue (pump, relay, fuse) if not there is a spark control issue, could be a bad module, or coil. What engine is it?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
One way to test you fuel pump is this... You will find a red wire with a sort of connector on the end of it next to your aux battery terminal. Touch this to the terminal and you should hear the realy click on and the fuel pump power on. If your holding the wire to the aux terminal and the fuel pump shuts off (it should stay on as long as that wire is touching the terminal) your problem is there.
it's a 3.1
I forgot to add on my last post the check engine light has been since this issuse has been on going we have done everthing that everyone has said to try an it still wotn run nor will it start ... does anyone have any other i deas as to what the problem could be ... me nor my hubsand are machincs but would appreciate any help .. I have been racking my brain tryin to fix it
Well, you can read the code that the car is putting out and than tell us what code it is... It will be a seriess of flashes. I believe the diagniostic code is 23 (2 flashes than a pause than 3 flashes than a long pause and it repeats itself.) It flashes each code 3 times from the check engine light. The way to get your car to flash the code is by shorting out the only two terminals in the diagnostic port that actually have wires in them. The diagnostic port is located underneath your dashboard slightly ro the right of your steering wheel.
For about $15, you can buy a Haynes or Chiltons repair manual that will give you a lot of information, including how to pull the codes, etc... and the first time you fix it yourself, the manual will pay for itself. These cars with the 3.1 engine have known issues with the crank sensor, ignition module and ECM (computer), and the fuel pump and relay. Since all these parts will cause a no-start, pull the codes and shoot starting fluid in the intake as Jeff suggested. This will narrow the choices as to what to do next.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
