Old 02-28-2006, 09:40 PM
crxrookie's Avatar
crxrookie crxrookie is offline
Question turn signals not working
I have just bought an 89' crx si and the guy that i bought it from neglected to tell me that the turn signals didn't work. I have checked all the fuses and there all in good shape except for the dome light fuse that keeps blowing out every time I try to replace it. I know that the two are not entertwined so whats the deal?
Brake lights work ,l hazerd signals work , but wen you go to use the turn signal it clicks over but does not come on????
I have a parts car so if I need to replace something I can.
Old 02-28-2006, 09:43 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: turn signals not working
Mine didnt work when I got mine either, niether did my gauges...it was the turn signal/ backup light fuse....hazards worked though...
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-28-2006, 09:47 PM
crxrookie's Avatar
where is the turn signal backup light fuse? under the hood?
Old 02-28-2006, 09:49 PM
FrodoGT's Avatar
Nope its the no.1 fuse I believe...under the dash.
Current project:
Rio Red 91 hatch.
Old 02-28-2006, 09:58 PM
crxrookie's Avatar
checked it out its deffinatly not the fuse
Old 02-28-2006, 10:18 PM
jmacs jmacs is offline
did u replace the bulbs >_>
Old 03-01-2006, 05:43 AM
crxrookie's Avatar
well when i turn the hazerd lights on they work , and i think they use the same bulbs
Old 03-01-2006, 07:52 AM
ive had that before once with another car though. turning signal would click into place no flashing just a big gren turn light not flashing at all. untill i found out the defective bulb then it started to work fine. Try it out Bulbs arent expensive anyway right?
Old 03-01-2006, 03:40 PM
crxrookie's Avatar
well the light doesnt even come on when i click it when i'm going to turn . but if i turn on the hazerds they both blink like they should
