Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-28-2006, 08:26 PM
Rufnrdy Rufnrdy is offline
Transmitter Distance
I was wondering if anyone might know why I am losing distance on the keyless entry transmitter for my 99 tahoe, it used to work at 30 feet, now I have to be right next to it to make it work.
Old 02-28-2006, 09:02 PM
2000CAYukon 2000CAYukon is offline
Re: Transmitter Distance
Did you replace the transmitter battery?
//2000CAYukon
Old 02-28-2006, 09:55 PM
Yea, Sorry, I Should Have Said That, I Replaced The Battery Right When It Started Happening. I Also Re-synched It, Nothing Seems To Be Helping.
Old 02-28-2006, 10:55 PM
OK. Just wanted to be sure. I have taken them apart and cleaned the contacts under the button and that has helped. Do you have 2 transmitters? Are they both doing the same thing?
//2000CAYukon
Old 02-28-2006, 11:38 PM
Yea, I have both of the original transmitters, and that was one of the first thoughts I had, hey I'll just switch it with my girlfriends. But no, that one does the exact same thing.
Old 03-03-2006, 11:45 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Run through the whole programming procedure, not just a re-sync. This usually extends the range.
If that doesn't work, place the remote up to your chin and aim it up into your head and press the button. This usually doubles or triples the range because it focuses the signal.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 03-06-2006, 02:39 PM
swp5767's Avatar
swp5767 swp5767 is offline
The distance on mine is not all that great either. I bought mine used on ebay and programmed it. Even with a new battery, my range is 5-15 feet away.
97 Tahoe 2WD LT (mine)
00 Astro (wife's)
89 S-10 p'up (daughter's)
72 VW Beetle (mine too)
