Old 02-28-2006, 08:15 PM
2000 Silverado 4x4 2000 Silverado 4x4 is offline
Tool Question for Front End Crank
I have all the info for cranking the torsion bars and it must be somewhat simple if damn near everybody has done it but what I want to know is where did ya'll buy the 2 arm gear pullers? I've seen them here and there but I don't want to spend a hell of a lot on this thing if I'm only usin it once ya know?! Let me know where you guys went
thanks
PFC. Nick Spry
12/13/84--2/14/04
"How I Wish You Were Here"
2000 Silvy 4x4
3" PA Body lift
285/75/16 BFG AT's
K&N intake
True Duals, No Mufflers
2 10"Rockfords under rear seat facing out
Old 02-28-2006, 09:16 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: Tool Question for Front End Crank
The only tools you need to crank your torsion bars up is a 3/8" drive ratchet, a 3" extension which is not really necessary but it moves the ratchet away from the cross member, and if i remember correctly on the size, a 3/4" socket but i may be wrong. Now if you are swapping out the torsion keys for the ford keys that is a different story, you will need the tool for removing the keys that are in there and i heard it looks more like a C clamp and some places will axtually rent it to you.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 02-28-2006, 09:34 PM
FiTxAg04's Avatar
FiTxAg04 FiTxAg04 is offline
Yeah...If you just want to crank your bars you just need a socket wrench, but be sure you jack the front tires off the ground or the torque you exert on the bolt might be enough to break the head off (which, I imagine, is a problem you don't want to have to deal with).
As far as the puller, I got one from Sears for 40 bucks. Make sure, if you do this, that you get the 7-ton puller and not the 3-ton puller (not big enough). Now, Chevrolet makes a tool especially for unloading a torsion bar which, like he said, is just a beefy C-clamp that fits the frame cross member perfectly. This tool will run you about 96 bucks and I had absolutely no luck finding anyone to rent me one (like others on here suggested). But, I had absolutely no problem doing my swap with the Sears puller.
2004 Chevy z71
BF Goodrich T/A KO 285/75/16s. Flowmaster 40 Series exhaust. K&N intake. Stull billet grille. F-150 torsion bar index keys. 800w stereo system.
Old 03-01-2006, 08:04 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I used a pull handle and a deep well 18mm socket
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 03-01-2006, 04:28 PM
kbone77 kbone77 is offline
If you get a few inches out of your torsion bars you should also get a full front end alignment.
Old 03-01-2006, 05:11 PM
Yeah guys I meant swapping key for the ford keys, sorry it was late and after the sun goes down I am a retard . So it looks like Sears it is, thanks folks
PFC. Nick Spry
12/13/84--2/14/04
2000 Silvy 4x4
3" PA Body lift
285/75/16 BFG AT's
K&N intake
Old 03-01-2006, 09:28 PM
Rugerlab's Avatar
Rugerlab Rugerlab is offline
Send a message via ICQ to Rugerlab
Yeah i used the sears 7-ton gear puller as well and it worked perfect. I think it was an 18mm socket on the torsion nut and a 19mm on the gear puller. Other than that just jack stands and a jack. have fun
99 Chevy Silverado Z71 LS 5.3L ECSB
Old 03-02-2006, 11:39 PM
FiTxAg04's Avatar
Be sure to let us know how it goes!
2004 Chevy z71
