Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-28-2006, 07:05 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
OK, I have finally decided what to do.....4G64T
After doing more thinking and doing some research I have decided to simply turbo my good 'ol 4G64. I have been reading up on how to do it and I found this site that has alot of good info: http://www.4g64.150m.com/. I will be honest with you, I don't know alot about turboing a car or turbo cars in general, I only know the basics. So some of my questions may seem "newbyish", but please don't flame, just help if you can. My plan is to turbo the stock SOHC 4G64 and retain the stock ECU.
So anyways, I have some questions.
1. What would be some advantages of swapping to a turbo ECU and should I do this?
2. I am obviously going to have to upgrade the fuel system. I was thinking about 450cc injectors like the link above stated. If I switch to a 2g turbo ecu will I still need the SAFC?
3. I will upgrade the fuel system with a Walbro 190 pump and some injectors. Besides an SAFC what else will I need. Will I need a fuel pressure regulator if using the SAFC?
4. Will I need any additional tuning besides setting boost and tuning the SAFC?
5. I want to run around 8 psi for now. I may eventually build the bottom end and do the DOHC head swap so I can turn up the boost. With this in mind what will be the best turbo to install. The above link suggested a small 16g or a 14b.
6. I will use an aftermarket FMIC. Can I use aftermarket 2g turbo lower and upper intercooler piping?
These are all the questions I have for now and I appreciate any help given.
I am hoping to start on this sometime this year. I have enough to cover it all in my savings but I want to get a job first so I dont blow all my paper.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 02-28-2006, 08:05 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: OK, I have finally decided what to do.....4G64T
1. Swapping in an EPROM will let you run DSMlink. If its possible, I'm not sure.
2. If you are going to be running a 14b 450's should suffice, otherwise go bigger. I think you will still need some sort of tuning device because the turbo engine is only 2.0 and yours is 2.4. Again, not sure.
3. Assuming that the fpr in the 2.4 is the same as the 4g63 you will be fine with a 190. Either way, I would get an aftermarket fpr.
4. Dont really understand the question.
5. I'd go 14b for a while. I think you may be stretching those injectors with a 16g.
6. No since the stock pipes are for the SMIC.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-28-2006, 11:57 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
To have the fuel/timming maps for possitve pressure..
Any injectors larger then the 450's will require some type of fuel mangment..
You will need a 2g turbo FPR set to 43.5psi, 440's and no other tuning device... If you choose to get a 255lh or larger you will need an AFPR that will allow you to lower your fuel pressure; like the Aeromotive 13109..
If you choose to use an safc2 you will need a pocket logger to log RPM, Timing, 02, Airflow.. And of course a Wideband if you have the available $..
both have extreamly good compressor effencys for low boost.. The 16 just has a higher & wider effency... Choice is yours.. I would stick with the 14b to begin with becaue it won't outflow your walbro & 440's..
The UICP yes if you go long route, LICP, No.. You can get a suppra side mount to work with the stock intercooler pipeing... Most FMIC will require new pipeing...
DSM geek
Old 03-01-2006, 03:53 PM
Thanks for the help from both of you guys. I have another question. If I swap to a turbo ECU will I need the 2g 4G63t throttle body? And if so...why?
Caleb
vanilla gorilla
Old 03-01-2006, 03:58 PM
So your saying that if I go with the Walbro 190 and 440 injectors with FPR set to 43.5psi that I won't need an SAFC?
Caleb
vanilla gorilla
Old 03-01-2006, 06:19 PM
You need the 2g Turbo FPR, and it needs to be set to 43.5psi... You won't "need" the safc2. To do any tuning you'll need the safc2 pocketlogger combo..
You wont need the 2g TB, you can use the 1g TB with 2g TPS, Vfaq or RRE has a writeup about it..
DSM geek
Old 03-04-2006, 05:15 PM
yellowspyder's Avatar
yellowspyder yellowspyder is offline
Send a message via AIM to yellowspyder Send a message via MSN to yellowspyder
this really doesn't answer your questions at all and anyone feel free to correct me if i am wrong, buit i was reading some insructions posted on another forum about turboing the 4g64 without rebuliding to a dohc and i believe that if you stick with the sohc you can only run low levels of boost something like around a max of 10 maybe 12 psi, so that might be something to think about if you are looking for a big power gain or want to run a higher boost level.
1999 spyder
Old 03-04-2006, 08:17 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Thats because it has higher compression
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 03-05-2006, 05:43 PM
Yeah, well I'm only wanting to run around 8 or 9 psi for now. I'm just trying to get all the parts together right now and get it working. Later on I'll slightly upgrade the bottom end and do a head swap so I can turn up the boost.
Caleb
vanilla gorilla
Old 03-05-2006, 06:37 PM
grape_ape grape_ape is offline
Send a message via Yahoo to grape_ape
Lightbulb Re: OK, I have finally decided what to do.....4G64T
i think that you should get a motex system exhaust............or so says brian..........but hes a cop so he doesnt really know. I have seen fast and the furious 100 times so i know a lot about cars, like nos stickers give you 10 horsepower.....and if you have a hose hangin on the road cuhhhhhhhhh man bruh man you tearing up the 1/4 so watch out.........i could help you hook up something being that we home bois.....holla at ya boi because i..........have an idea
where did you get those cars from the bottom of a cereal boxxxxx
Old 03-05-2006, 06:43 PM
Dude, you trip me out. Good to have you on the forums.
Caleb
vanilla gorilla
Old 03-05-2006, 06:59 PM
you want your car to go fast i mean seriously are you crazy in the head and anyway why you asking us about all these illegal parts for..................you a copppppppppp
Old 03-05-2006, 07:14 PM
hey brah man why you even got stuff about your ferrari on a mitzu forum anyway dude.........you must be smokin that japan stuff
Old 03-05-2006, 10:59 PM
Thor06's Avatar
Jizzed In My Pants
No way, your a cop? I nominate your life as the biggest contradiction of the year .
EDIT: Shit my bad, I missed the F&F reference...
Old 03-06-2006, 12:16 AM
He's going undercover into the underground street racing to catch the bad guys in green honda civics...
DSM geek
