1998 Mit 3000GT SL SOHC/DOHC Help!!
How can you tell if my 1998 Mitsubishi 3000GT SL is a SOHC or DOHC? Also I how do you change the wires and plugs, researched but only found the VR4 post. I can do the first three under the spark plug cover but the other three look tough. I am trying to get a set of manuals now. I have a 88 Quest and 89 Starion and do most of the work on them. Thanks,Gary
Re: 1998 Mit 3000GT SL SOHC/DOHC Help!!
Dohc.
Yes, only teh base models from 97-99 were SOHC
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
lol... all you really had to do was pop the hood and it says it right on the top of the plenum...
Georgey on the subject of midget beastiality pornos Quote:
R.I.P Andy, you will be missed by all. |
The front valve cover should say DOHC, so should the upper intake manifold(plenum)
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions. |
or you can look at your rpm, if it red line up to 8 then it sohc, if it's 9 then is dohc
Step-by-step instructions on changing your plugs: http://www.team3s.com/FAQplugs2.htm One thing to that was different on my '94 SL was that there is an extra bolt that is connected to the plenum that isn't mentioned in the guide and 2 bolts that hold this one other piece onto the plenum (there's also a small silver gasket there so don't lose it when it falls out...I almost threw mine away ). Not sure if it'll be the same for yours but just a heads up. Good luck!
An SOHC spark plugs are all easily accessible. DOHC spark plugs have under the spark plug cover and 3 under the intake manifold.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
^^$300 to install some plugs and wires???? NO WAY!!! That's a total rip off! Definitely do it yourself and come on the board to ask questions if you get stuck. There are A LOT of well experienced people here who could help you. Furthermore, those step-by-step instructions basically tell you everything you need to know as far as replacing your plugs go. Just remember to number your bolts as you take them off and don't drop any nuts (I dropped 1 into the engine bay somewhere and had this bright idea of dropping the other one to find out where the first one fell and ended up not being able to find either of them
LOL).
yeah i have a dohc base and it redlines at 7
