Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 02-28-2006, 04:29 PM
FstrThnLfe0219 FstrThnLfe0219 is offline
Windshild Sprayers!!! Please Help!!!
I purchased the car not to long ago and the sprayers arnt working. It is fully filled with wiper solution. Could this be an electrical problem? Any suggestions?
Old 02-28-2006, 04:36 PM
Drodman Drodman is offline
Send a message via Yahoo to Drodman
Re: Windshild Sprayers!!! Please Help!!!
Well it sounds like you should have not purchased this car. You have some minor problems right now that should easily be fixed. With the help of some of these guys on this board you will get some answers and some ideas. Take everything to heart as some of these guys know a ton about there cars. I am new here as well and I am just learning about my car. If that was my car and had those problems I would take it to a friend of mines garage and have him look at it and tell me what exactly I needed to do. Other then that I don't know what you can do.
Make sure you read the thread about modifying your car it really helps a lot.
MODS:
2001 Mitsubishi Eclipse GT Spyder,17" Konig Wheels, AEM Underdrive pully and Air Intake System, B & M Short Shifter with MOMO boot & shift knob, High Performance Drilled & Slotted Roters w/Hawk Brake Pads, Centerforce Stage 2 Clutch, Fidanza 9lb Flywheel and a Magnaflow Full Catback Exhaust System.
Old 02-28-2006, 05:08 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Make sure that your lines are all good, and connected to the sprayers. Also, make sure there is no crud in your sprayers. Does your motor sound like it is working?
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 02-28-2006, 05:18 PM
yeah the motor is working. like u said it is probably the line connection or crap could be stuck in the sprayers. thanks
