Old 06-29-2002, 12:30 PM
neunan neunan is offline
Send a message via AIM to neunan
Angry power lead problem? deck install
so... i finally got my car back from the clutch/flywheel install, and first thing i do of course is try to get my cd player back in and working. initially it did nothing, then i discovered a fuse was blown. i replaced it, and the cd player worked fine for about 30 seconds and then it died again: fuse blew again. so i replaced the fuse again... and it didnt work. ??? to troubleshoot i put the stock tape deck back in which worked fine before this, and the red "security" light flashes, but it wont turn on either. im lost... it has to be something with the original harness coming from in the cavity. i think. any help would be appreciated. im leaving in a couple hours for hot import nights, Chicago, so faster help is better! thanks
96 Accord EX 5spd coupe - black
AEM cai * DC Sports cc 4-2-1 header * GReddy EVO catback* AEM trupower pullies * ACT HDSS clutch kit * ClutchMasters 8lb flywheel * NGK blue wires * 4 wheel Brembo slotted rotors with AEM pads * 4bidden Motorsports shortshifter
pioneer deh9300 * phoenix gold zero point wiring * blaupunkt pa2100 pushing diamond audio HEX 6.5 comps in front * blaupunkt pa275 pushing power acoustik fahrenheit 6x9s in back* 5" LCD TV * 8-bit original NES
Old 06-29-2002, 12:40 PM
93speed's Avatar
93speed 93speed is offline
Check all wiring. From your description it sounds like theres a short somewhere. Make sure no bare wires are touching the metal. Double check you have all connections insulated. Try that first. Rule out the easiest before you start ripping everything apart.
Hope this works for you
Old 06-29-2002, 02:54 PM
well i made sure the wires werent crossed or bare on the adaptor, but my problem comes before that. its either in the wires coming out of the cavity or the harness that came with the car that they're all attached to. oh, and now my turn signals dont work... the hazards are fine, and the fuses for the turn signals are good, but they dont do anything. why me..heh
Old 06-29-2002, 05:36 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
rewire the power and ground wire to a different source. for the constant 12v lead, hook it up directly to the car battery (make sure it's fused). run the the ground wire to a different source, like to the chassis. for the constant ignition, wire it to the blue/white stripe wire of your ignition (near where you put your key in). the purpose of this is to run bigger wires (which i recommend 12 gauge). stock wires may not provide enough power and causes shorts sometimes. i had this problem before.
Old 07-01-2002, 03:46 PM
thanks for the help guys, i got it. this post can fade into nothing now
