Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 02-28-2006, 03:34 PM
George_911 George_911 is offline
Question Codes
I have a 1997 Pontiac Sunfire with a 2.2 litre engine and an automatic transmission,and it has 101,000 on it as of right now..The problem is my check engine light came on and it stays on continuously...I took a Scanner and read the codes just a little while ago and it is reading out 4 different codes and I was wanting to see if anyone can tell me what these codes mean?? The code numbers are:::P0121 P0341 P0420 and P0335...if anyone out there can tell me what these codes mean I would surely appreciate it......
Old 02-28-2006, 04:08 PM
GMacK105 GMacK105 is offline
Re: Codes
po121 is throttle/pedal position sensor/switch a circuit range/ performance problem
po335 is crankshaft position sensor A circuit malfunction
po341 is camshaft position sensor circuit range/performance
po420 is catalyst system efficiency below threshold (bank 1)
Hope that helps those are all the OBDII generic codes.
