Cccc
I have done a search on this and Ive got a lot of my questions answered already, but I still need some advice.
My system is blowing hot no matter what, I understand that it could be the door stuck, or the actuator. when I have the truck running I can hear this very quiet grinding noise, not all the time just every now and then. lasts about 3-5 seconds ..like its trying to open the door. I have replaced the switches, and traced all the vac lines, "that was fun" all looks good. Now what I am looking for here is any advice, pointers, instructions or any information that I can use to fix this......Thanks Guys.....
08 Equinox LT |
Re: Cccc
The door gear is stripped or is caught on something. Hence the gear grinding noise.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: Cccc
ty,ty,ty,,,,,now i have alot of work to look farward to...
08 Equinox LT |
Re: Cccc
Nah, not that much to gain access to the door.
Re: Cccc
From what I understand from doing the search I have to dismantal the dash. Is this incorrect? If you know an easyer way I would sure like to know...Links pics and what not would be most helpfull...if not while Im doing this ill take pics as I go along....Thanks
08 Equinox LT |
Re: Cccc
I might have been mistaken then.
I would see if someone can lend you the instructions for it. Some of the forum members have access to the automotive service manual library.
Re: Cccc
That would be great!!! Could someone lend me these instructions, please?
08 Equinox LT |
Re: Cccc
This sounds like a common problem. I had the same thing happen to my 98 jimmy with the electronic climate control. Took it to my mechanic and he said there was a motor in the dash that opens and closes the door and it was broken. I have no clue if this will help you but that was what was wrong with mine. Good Luck. |
Re: Cccc
Ive got the lower part of the dash diassembled right now. I will tackle this project this weekend, taking pics along the way. it sure would be helpfull if I had some type of instructions to follow so I dont remove something that I dont have to, plus Know were everything is....I have a chiltons but it just gives a general idea of how to take the dash apart.
08 Equinox LT |
Re: Cccc
Anyone got an instruction set for this chap?
Re: Cccc
I'll see if I can find something when I get home today. I'll probably be doing this sooner or later anyway.
Re: Cccc
thanks!!!!!
08 Equinox LT |
Re: Cccc
oh tay....here we go....so far I have gutted the dash, speedo, radio a/c controles. I have removed the pass side pivot bolt and I cant find the drivers side....the pass side seems ready to come out. were is this stinking bolt? the truck is apart and I cant go any further....ill be sitting here awaiting an answer......lol
08 Equinox LT |
Re: Cccc
You might be able to get to the motor if you remove the glove box, (can't remember for sure). If not, ya gotta crane your neck way around and up to see the bolts, very close to the top of the kick panel, and it seems to me there's two bolts on each side that need to be removed. Once you've located them, if you put your hand in there to remove them, you can't see the bolts, just have to go by feel. I think it's a torx head, maybe 25 or 30. The bolt is in the same position as the passenger side, (tucked neatly out of the way). Don't forget to hold your tongue just right, and squint your right eye, kinda like this >>>
Re: Cccc
If you're trying to pull the whole dash, There are two bolts at the bottom. (one on each side) they are 10mm. Below the steering column there are two "L" brackets, each bracket has 4 - 10mm bolts, you'll only need to remove the ones that are hard to get to. On top of the dash, there are 6 - 7mm screws. One under each speaker grill, and four under the defrost vent.
With that said, I'll have to look again when I get time, I was thinking that it could be accessed through the glove box. |
