Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 02-28-2006, 04:04 PM
workingout's Avatar
workingout workingout is offline
'96 Clutch Slave Cylinder RnR
Just went to leave the house and car will not go into gear, clutch pedal has no resistance, and there is Dot 3 fluid on the drivers side floor mat.
I just filled the resevoir last week when shifting into 1st became hard, it is now empty. I refilled and it is visibably leaking. When the car was given to me I was told the Slave Cylinder is bad.
I have some expereance, 4 years in dealerships and independent shops, mostly undercarrage stuff
TWO Questions: does this sound like a Slave Cylinder problem?
AND: if it is... is this something I can RnR in my driveway and how much time does the flat rate manual allow for it. if its over 4hr I will take it to a shop. Cus that means it will take me 8, and thats not worth the money I'd save.
Get a bigger hammer.
My Johnston Rod got caught in the Pittman Arm
Old 02-28-2006, 04:24 PM
workingout's Avatar
Re: '96 Clutch Slave Cylinder RnR
A local dealer quoted me $28.75 for the part (a clutch slave cylinder) and 0.5 hrs for labor. Does that sound right.
Old 03-02-2006, 09:34 PM
workingout's Avatar
The fluid on the floor mat was from the Master Cylinder. I took it to a shop and had both done. I did not want to bleed the system. It was well worth the $74 in labor to have someone else do it.
