Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-28-2006, 02:02 PM
lovemybadkitty lovemybadkitty is offline
Smile TCC switch replacement
I have a 92 Grand AM with a 3.3l engine and I guess a TH125c transmission. I can drive the car sometimes quite a while and all of a sudden the torque converter locks up eveytime I stop. I was told it may be the TCC switch. How can I get my hands on something that will assist me on changing this switch? Seems like the little autozone repair guides don't cover this switch in great detail. Is there like an additive that might make this switch work better?
Old 02-28-2006, 05:20 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: TCC switch replacement
Welcome to AF!!
The TCC solenoid in the TH125C is easy to get to and change. You will probably have to go to a dealer to get the solenoid but changing it is very easy. Once you have the solenoid jack the car up on the drivers side and remove the wheel and the inner fender. Directly in front of you is a metal cover that bulges slightly. Remove the bolts that hold the cover on and remove it. Put a pan under it as there will be small amount of fluid that comes out and will probably drain the entire time you have it off. Remove the bolts/screws that hold the solenoid in place and unplug the wire. Reinstall the new solenoid and route the wires. The hardest part of the entire job is connecting the wires back up inside the transmission as the space is limited. Once you have everything secured and connected, replace the external cover, a new gasket comes with the solenoid. Replace the inner fender and the tire and you should be good to go. Check the amount of fluid you lost but I doubt it will be enough to require replacement but check to be certain. Good Luck!!
Old 03-01-2006, 06:56 PM
Thanks to GTP for the info. Great response Time.
Old 08-12-2007, 11:59 AM
smokey_1145 smokey_1145 is offline
would the same thing apply to a 92 grand am 2.3l sohc engine?
Originally Posted by GTP Dad
Welcome to AF!!
Old 08-14-2007, 05:39 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF smokey_1145.
Please look at the dates before posting!!!
We dont like to bring up threads older then 3 months,
you can post a link refering to an older thread though.
BUT To answer you question, yes it does apply.
and if you have further questions please post your own thread/topic.
as this is closed
1999 Grand Am SS 3.4 OHV
Closed Thread
