Old 02-28-2006, 01:04 PM
kb3jhp kb3jhp is offline
shift delay
i have a 96 blazer 4X4 and have had trobel with it haveing a delay shifting in to 2 same as blazerLT in form http://www.automotiveforums.com/vbul...light=12167310
so i thougt it was slipping so started out in 1 and floored it no slip did the stall test no slip.put it in 2 and floored it it down shifted my dads 96 bravada does not do this. does any one elses blazer downshft out of 2 when gear sel in 2 wat is cauesing the delay and if i keep driving it will it burn the cluctes up thanks
Old 02-28-2006, 01:27 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: shift delay
May be time to check it for the updated PCM wiring change over.
What engine and trans?
Has it ever been serviced? What is the milege? Pull the transmission pan and check the filter and see if anything is in the bottom of the transmission pan.
I think BlazerLT said his was leaking coolant into the tarns fluid.
If yours has that problem you cans see signs of coolant in the bottom of trans pan like orange or green tint.
Does yours have a PCM or VCM . What is the built date and VCM or PCM service no?
MT
MT
Old 02-28-2006, 03:15 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: shift delay
This could be a few things. I doubt its the TSB for the ground, as it relates to the P1870 code. Do you have any trouble codes come up? Pull the pan, and take a look at the condition of the fluid and see if you see anything. If you have no trouble codes, and your fluid is good no metal or fricition material in the pan, I would be taking a close look at the valve body, and the servo pistions.
heres a link to a popular sites that has solutions to some of these problems, just to give you an idea what trans shops use to fix these trannies.
http://www.transmissionspecialty.com.../DM/4L60-E.htm
Old 02-28-2006, 03:23 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: shift delay
Yip, you need the updated tranny PCM ground.
I will be installing it this week.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-28-2006, 03:24 PM
Re: shift delay
thanks for repling mine has the 16244210 number and i changed the filter and fluid it has 126000miles and has the 4l60 4.3vortec wat would it cost to get the servo fixed at a shop dont have the time could it still need the update
Old 02-28-2006, 03:25 PM
BlazerLT's Avatar
AF -Advisor
Re: shift delay
Itr isn't the servo, it is the ground for the tranny portion of the PCM.
The internal ground is not adequate and causes high line pressure.
Old 02-28-2006, 03:32 PM
Re: shift delay
could it still be the ground update that is needed if i have the 16244210 number also does yours down shift from 2
Old 02-28-2006, 03:34 PM
BlazerLT's Avatar
AF -Advisor
Re: shift delay
huh?
What is that number for again?
Old 02-28-2006, 03:36 PM
MT-2500's Avatar
AF - Advisor
Re: shift delay
Yes as said the servo can cause shifting problems on it to.
I will check your VCM no.
Not that the info here is not good but here is a link to a good transmission man.
His name/handel is Transman.
Hit him with a post and see what he has to say on it.
http://www.batauto.com/cgi-bin/Forum...rum_name=trans
MT
Old 02-28-2006, 03:38 PM
Re: shift delay
it is sed if you have the number you do not need the update
BlazerLT's Avatar
AF -Advisor
Re: shift delay
True, it will cause it, but most 1-2 shift flares are caused by the bad ground.
Old 02-28-2006, 03:41 PM
Re: shift delay
does any of you guys blazer down shift when you put it in 2 and floor it
Old 02-28-2006, 03:52 PM
MT-2500's Avatar
AF - Advisor
Re: shift delay
Go here and read the no 6 post that was posted on the ground TSB.
http://www.automotiveforums.com/vbul...91#post3869791
It says or I undestand it to say that VCM 16244210 is the updated VCM
MT
MT
