Old 02-28-2006, 12:20 PM
TheFuzz TheFuzz is offline
Exclamation front end rattles pls help
so i just replaced the inner tierod cuz there was a rattle and they were way bad but the sound did not go away and im lost any ideas
Old 02-28-2006, 07:00 PM
Crx Guy Crx Guy is offline
Re: front end rattles pls help
Well when does it rattel ? It could be upper and lower ball joints.
Old 02-28-2006, 11:51 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
huh. might by a dumb thing to say but i couldent figure out why my front end kept rattling but it was just the hood hitting the fender. huh
Old 03-01-2006, 01:41 PM
well i know it is the parts in the susp. and bolth lower ball joints are new.
it is just when i go over bumps it could be stuts or outer ball joints mabey bushings any other sugestions. thanks
Old 03-01-2006, 06:51 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
...motor mounts...old bushings, if you have an after market air filter it could be hitting your fender or something, is your car lowered? if so are they coilovers on stock struts? did you use them little rubber o-rings?
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 03-01-2006, 08:54 PM
Hybrid1990crx's Avatar
Wiggle your steering whell left and right? Any freeplay? If not then tie rods are good.
Jack your car up. Shake the tire holding it at 6 and 12. Any freeplay? If not balljoints and wheel bearing are good.
Shake the tire holding it at 3 and 9. Any free play? If not tie rods are definetly good.
Look under you bumper and youll see torsion bars, are they loose?
How is your shift linkage stabilizer bar bushing?
Are you shock towers fully tightened? How are the strut busings?
