Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-28-2006, 12:09 PM
amy123 amy123 is offline
92 Crown Vic 4.8 V8 Overhead Cam
Afternoon,
I am trying to find out how to remove/replace oxygen sensors - can someone get me started in the right direction?
Thanks,
Amy
Old 02-28-2006, 02:42 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 92 Crown Vic 4.8 V8 Overhead Cam
Which sensors are you wanting to replace and why. There are 4 sensors on your car. 2 are right behind the engine just below the manifold on either side. The other 2 are located between the converter and collector. The last 2 are easy to see and get to. The 2 front ones are kinda buried under the exhaust. It takes a 7/8 wrench or a O2 socket to replace them.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 02-28-2006, 04:27 PM
Need to replace because there is oil covering the sensor and no read out is available - if you are standing in front of the car it is the sensor on the left - the front 2 as you stated on either side of the manifold - I know we will have to buy a special tool for removal - thought we could remove ourselves and save some $ - might be better to replace both at the same time?
Thanks,
Old 02-28-2006, 06:40 PM
way2old's Avatar
TOKEN HILLBILLY
If it is on the passenger side front it is bank 1 sensor 1. If the sensors are original(probably) I would replace both. Might even consider the rears in the future.
Old 02-28-2006, 09:28 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
not to disrespect you way2old but there are only two scensors on the manifolds for that year not sure what years there was 4 but there is only two for the 1992 and you can get a special tool from any parts store that is a socket with a side cut out to fit the wire around and do them from the top ive found its not to hard but the pass side connecter is bout the hardest part so good luck
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 03-01-2006, 08:26 AM
Thanks for the information - is there somewhere I can look that will tell me exactly how to remove/replace the sensors?
Old 03-01-2006, 09:05 AM
way2old's Avatar
TOKEN HILLBILLY
There is no special technique needed to replace the sensors. Just have the tool to remove the sensor and install new one. The hard part is getting to them. Since cobradude refreshed my memory, these are just barely accesible from the top. It is very clese quarters, but you can remove them. You are right cobradude. I got OBDII stuck in my head now. This one is an EECIV. Thanks for jogging my memory.
Old 03-01-2006, 09:08 AM
Excellent - I will attempt this weekend.
Old 03-01-2006, 09:27 AM
no prob i was able to do them from the topjust a few weeks ago so i know it can be done just have patience
