Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 02-28-2006, 08:47 AM
jet73703 jet73703 is offline
1986 fiero 2m. HELP!!!
My 86 fiero 2m (4cyl,auto,stock) is getting to much gas, which in turn is causing it to accelerate terribly. it hesitates and jumps. getts better when going faster. air filter is clean.Any suggestions??????
Old 02-28-2006, 09:22 AM
Re: 1986 fiero 2m. HELP!!!
anyone???
No one has any idea what the problem is?
Old 02-28-2006, 12:27 PM
MrPbody MrPbody is offline
AF -Advisor
Not specifically, no. Sorry. It sounds like it's time to take it to a shop that has a good electronics guy. You either have an injector hanging open or too much fuel pressure. It's worth the fee to have an expert diagnose the problem.
Jim
Old 03-01-2006, 09:31 AM
i heared a couple of other possible solutions...
02 sensor
vapor canister
fuel return line
Old 03-18-2006, 01:06 AM
farewarning farewarning is offline
Send a message via AIM to farewarning
Cool Re: 1986 fiero 2m. HELP!!!
Try changing the Egr valve that might help somewhat. Is your car reading any codes?
Old 03-24-2006, 05:15 AM
Joe442 Joe442 is offline
Re: problem with with what is wrong with my car
i have a 2.8 v6 fiero SE 2M6 rebuilt
The only after market parts are
auto light platnum tiped plugs,
Megafire distributor chip,
excell injectors.
i rewired the harness with bigger gauge wire 10 gauge. i put all new gaskets distributor rebuilt, with new coil,split fire wires.
when i try to start the engine there is no spark no feul preasher. There is no engine light when i used my code scanner on acsesorys. Only light that is on my dash is jar. there is power to the harness, the feul pump works with an external power suppliy that i used. I changed the coil both dont deliver spark to distributor. Anouther thing is that the computer itself gets warm. not shur what that means.
