Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-27-2006, 11:24 PM
Airdale Mech.950's Avatar
Airdale Mech.950 Airdale Mech.950 is offline
????? about Valve timing
Okay so I lined up my cam gear and timing belt and 1piston at tDC took off the timing belt put my skunk2 gear on put everything back on and now it wont start this fn sucks I thought I did everything right and its such a Bisnitch taking and putting the timing belt back on and off. What am I doing wrong.. The other mech in my shop said that once you take off the timing belt the piston will tend to drop on its own is this true?/ Did I take to long to put the belt back on?? What might be the problem?? My valves aren't bent or hitting so thats good when I tried to start it it just had a hollow backfire......Adn when I did a compression test so the compression was only like 75 80 normal is like 135... Are my valves no closed all the way how do I fix this problem any advice will help Im tryin to fix this myslef or else I will just have to take it to a shop and have it professionally done....
RTC Great Lakes
NATTC Pensacola
CVN-68 U.S.S. Nimitz San Diego
93 Del Sol D16Z6 Greddy 4-2-1 Greddy Evo2,
AEM cold air
MSD Ignition wires
15' GSR rims
http://www.myspace.com/ghostryders
Old 03-13-2006, 11:57 PM
blitzcivic's Avatar
blitzcivic blitzcivic is offline
Re: ????? about Valve timing
well its sounds like your timing is off so i would start from scratch with the timing just be patient double check your self , and your compression is very low you may have a serious problem with that. but first check your timing use a chiltons book.
1993 HONDA CIVIC EX
BLITZ FRNT M3 SIDE BLACK WIDOW REAR
JSP TERMINATOR WING
17' MOTEGI SUPER SILVER RIMS
D16Z SOHC 1.6 VTEC
SKUNK2 INTAKE MANIFOLD
CROME TUNED ECU
B&M FUEL REG
DSM 450CC INJ.
MSD BLASTER COIL
APC 9MM WIRE
GREDDY BACKCAT EX
T25 CUSTOM TURBO KIT @ 7PSI
TUBULAR MANIFOLD
AIR TO AIR INTERCOOLER
ALCOHOL INJECTION
18002 TURBO MILES AT 218002 MILES GOING 140MPH FINALLY WENT
BUT, STILL GOT ME HOME
Old 03-26-2006, 08:55 PM
Yeah I solved that problem by swaping a GSr into it
RTC Great Lakes
NATTC Pensacola
AEM cold air
MSD Ignition wires
15' GSR rims
Old 03-26-2006, 08:57 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Did you take off your crank pulley, and set the crank at TDC. Or, did you half ass it, and leave it on, while just trying to change cam gears?
