Old 02-27-2006, 11:08 PM
rental blazer rental blazer is offline
How Many Miles Does Your 4.3 Have
I thougth it would be interesting to see how many miles people have on their 4.3 without a rebuild..please mention if its a tbi or vortec and how well is it mantained and last how do you drive it?
Old 02-27-2006, 11:22 PM
Teal95Jimmy's Avatar
Teal95Jimmy Teal95Jimmy is offline
Send a message via AIM to Teal95Jimmy
Re: How Many Miles Does Your 4.3 Have
I have a 95 with the vortec that just turned over 98k miles. Only mechanical things changed were the fuel pump, alternator, the the lower intake gaskets, and the exhaust come some warmer weather. Along with usual maintenance parts.
Old 02-27-2006, 11:24 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
i got a 95 jimmy with 205,000 miles on it. i don't abuse it but im not affraid to let it scream once and a while. its got its issues and i may bite the bullet and get rid of it soon.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 02-27-2006, 11:34 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
2000 Vortech with 82000. In DIRE need of a tune up!!!
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 02-27-2006, 11:50 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Well original 4.3 in the 91 went 169 and change.
The V8 went all of 15 miles.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 02-28-2006, 07:46 AM
scholzee scholzee is offline
1996 2 dr 4x4 190K and has had a Western 6'6" plow on it its whole life. Plow Mine and my families driveways about 5 total here in Buffalo NY. Can carry that plow up to 80 miles a day sometimes in some pretty bitter snowy conditions.
Old 02-28-2006, 10:11 AM
billibong's Avatar
billibong billibong is offline
1999 4.3 Vin W 4X4, I have owned it 3.5 years. When I bought it it had 37000 on it, it just rolled over 120000. I keep up with maintenance, and it runs pretty well.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 02-28-2006, 10:35 AM
AJT1961 AJT1961 is offline
2000 Blazer 4.3 4x4, 106,000 miles. Purchased new, replaced alternator at 65,000, cat-back exhaust at 75,000, lower intake gasket, lifters and oil lines at 105,000. At 50,000 miles I had the tranny fluid changed by machine, at 100,000 I dropped the pan, changed the filter and added 4 quarts. I plan on taking it somewhere for a machine change soon. Embarrassed to admit that I used Jiffy Lube every 3000 miles from new to 75,000 miles (my wife drove the car then) and they never once lubed the front end. At 75,000 I noticed a squeak in the front end and found the problem. Since then, been doing everything myself and will need to replace the ball joints as soon as the weather permits because of Jiffy Lube's lazy incompetant a$$holes. Runs great, but I'm overdue for plugs/wires/cap/rotor since I'm still using the originals. I'm thinking about throwing in a new radiator this summer too because of BlazerLT's post.
Old 02-28-2006, 10:39 AM
rlbck38 rlbck38 is offline
'95 Blazer LT 4.3 Vortec
Did regular maint. and crapped out at 140k.
looking for a replacement now.
Old 02-28-2006, 11:02 AM
utahdanb utahdanb is offline
97' Vortec, 205,900 miles. regular maint. i baby it a little, fix what i can and when i can. i have had it for 3 years and it has been the most dependable veihical i have had.
Old 02-28-2006, 11:09 AM
534BC 534BC is offline
95 vortec with 175,000
This week I am putting plugs, wires, radiator, cap, rotor, shroud in it. I did the tune-up stuff at about 80,000 - 100,000 and bought it at 76,000.
I don't believe in doing mainenance,,,, just repairs. It has had a water pump, fuel pump,gas tank, 3 sets of front brakes, 2 different swaybar links, 2 sets of tires, lots of oil and filters, a reuseable air filter
Old 02-28-2006, 11:10 AM
2kTrailBlazer's Avatar
2kTrailBlazer 2kTrailBlazer is offline
Send a message via AIM to 2kTrailBlazer
I have a 2000 4.3 vortec I do believe that they only put the vortec in the newer models..Am i Correct? I just turned 100000 last night! no huge problems replaced the alt and the oil cooling lines and regular maint. Used to beat on it, now im kid to it. Out side of the motor i replaced the front dif . That has been the biggest repair i have done...
Old 02-28-2006, 11:30 AM
Ultrashock's Avatar
Ultrashock Ultrashock is offline
Mines a replacement Jasper Engine with about 40,000 miles on it...... I abuse it way too much
Its a Vortec
92 S10 Blazer Sport
4.3l Vortec V6 (W)
275,000 miles
Jasper engine, Rebuilt tranny + rearend
04 Pontiac Grand Prix GT
43,000 miles
Old 02-28-2006, 07:58 PM
mines a 95 i got it with 106,999.9 now it has 118,600 ish i change oil every 3000 miles myself i just today replaced motor mounts, manifold gasket, and freeze plugs as well as cap,rotor wires and plugs since i plan to take a long trip this weekend so i needed all the small itty thinsg fixed to ensure a good trip i drive it normilly and not afaid to let it scream every once in a while ... so far just as my 85 blazer was both have been good to me
Old 03-02-2006, 09:56 PM
black wall st black wall st is offline
I have a 96' Vortec, 191,253 miles.. No overhaul, regularly maintained, and ive put atleats 50 thousand of those miles towing or pushing 22's, or doing both... I did have a seal go on my intake manifold, but i knew a guy that hooked me up, also like everyone else i have replaced the fuel cell, and the door pins... i love her...
