Old 02-27-2006, 09:31 PM
moneythang13 moneythang13 is offline
Problem with multisession switch(clicking noise) and another minor problem
Im a new memeber of this website and I've been reading all these posts on the clicking multisession switch and i just started having the same problem back in december with my 99 grand am se. Can someone please let me know the easiest and most accurate way to fix this problem.
Another thing, the beep after i press lock doesn't work anymore on my keyless remote entry. It locks but no beep and it really pisses me off. Should i try to reprogram it????? Answer please
Old 02-28-2006, 11:29 AM
rockfan0005 rockfan0005 is offline
Re: Problem with multisession switch(clicking noise) and another minor problem
Alright the tools you will need to start:
T-10 Torx Screwdriver
T-20 Torx Screwdriver
Electronic Contact Cleaner
Cotton Swabs
Di-Electric Grease (I used lightbulb grease, and it worked fine)
Tape
First remove the screws under the steering column with your T-20 Torx. Then unclip the three things in the back, remove the screw on to of the multifunction switch.
Here's the tricky part, wrap the wiper arm of the switch with a few layers of scotch tape. Then use the T-10 to remove all of the screws on the back of the multifunction switch. Pry open the switch on the wiper side (be careful), wipe off the the contacts with the cotton swabs, once its clean regrease it. Put the screws back together and take the tape off.
PAY CLOSE ATTENTION BEFORE GOING ANY FURTHER!!! THIS IS VERY VERY IMPORTANT!:
DEPRESS THE SPRING PIN, DO NOT Put it in there without depressing it (pushing it in) or else your horn won't work. Plug the three plugs back in and put the screw on tap back in. Put the plastic casing back together, and put the three screws back in.
If you have any problems PM me and I can help you.
2001 Pontiac Grand Am SE V6 3.4L
Mods: (More to come)
Cold Air Intake
SLP Exhaust System
DHP PCM
Old 03-02-2006, 09:53 PM
tracker5 tracker5 is offline
I got a 2000 grand am i have the clicking sound coming from the dash above the radio,When i turn on the left or right dir. it stops Any clue what it could be & how to fix it ? Thanks
