condenser fan
I have a 1993 accord with a fan problem.The condenser or coolant fan will not come on when I turn on the a/c.I have checked all fuses and relays including the one under the hood on left side.I have no power to the relay.Both fans will come on when the water temp gets high.I am praying I don't have a broken wire somewhere.I have read that both fans should come on when the a/c is turned on,but only the condenser fan would come on in the past.Any input would be greatly appreciated.Summer is not far away here in the south.
Re: condenser fan
Low refrigerant charge will prevent compressor operation. First thing to check is the system charge.
The aux fan will only run if the compressor is engaged, or on request from the PCM for engine cooling.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
