Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 02-27-2006, 02:49 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
idle problem
1989 bII, idles high at about 1050rpms, then will jump to about 1200 than back down. I have cleaned TB, IAC, even put a meter on IAC getting 9.1 ohms. Could a small air leak in the IAC gasket cause this?
Old 02-28-2006, 10:08 PM
0tobe60in10minutes's Avatar
0tobe60in10minutes 0tobe60in10minutes is offline
Send a message via AIM to 0tobe60in10minutes
Re: idle problem
whats IAC
RIP 88 Bronco II
Old 03-01-2006, 08:25 AM
scuba4321's Avatar
Re: idle problem
IAC= Idle Air Control
it is the small cylinder shaped item located on the intake manifold on the passenger side. It allows just enough air to bypass the throttle body plate to idle the engine.
