Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-27-2006, 01:54 PM
tela4422 tela4422 is offline
One of the lugs broke off....
One of the lugs broke off and took the threaded part with it. Now the wheel kinda wobbles. Do I change the rotor or something else so I can put all 5 lugs on?
Oh...I have tuner lugs on this car and I dont have the key. Anyone know where I can buy a new set so I can get a key?
Old 02-28-2006, 02:18 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: One of the lugs broke off....
Originally Posted by tela4422
One of the lugs broke off and took the thread...
Check out the exploded view from tha manual, for that u need start clicccing given links. On some cases u need to buy/replace the bearing assy, some cases u need only the bolt. Ask local stealership first [bolt swap cant be pricey], after that shock go to any other spare shop.
Wobbling means its gonna break & warp all...
Old 03-03-2006, 10:40 AM
J_Swaleh J_Swaleh is offline
you can buy a lug and lug nut set from kragen/autozone for 3-5 bucks. the replacement is sinple. take off the wheel and the rotor assembly. the rotors are held on the two bolts behind the rotor. then just take a hammer and a punch to hammer out the broken lug out the back of the rotor. to replace the it, take the new lug and stick in through the back. take the lug nut and tighten it dou=wn as tight as posible to pull the lug all the way into place. then unscrew the lug nd replace the rotor and the wheel with the new lug and lug nut.
Old 03-07-2006, 04:39 PM
Talking Re: One of the lugs broke off....
got it. Replaced the studs and she rides smooth. Thanks guys!
