Old 02-27-2006, 01:11 PM
Blazer SS Blazer SS is offline
Stupid!stupid!stupid!!stupid!!!stupid!!!
Did I say that I was stupid? When I got off of work this morning I figured that I would run a few errands before I went to sleep, I stopped by the Post Office and shipped a package, no problem , I then stopped by Autozone to pick up a new oil filter and some seafoam, I figured that I could change the oil filter In about 2 minutes, I wanted to try out that new K&N oil filter, changed it in a minute and a half!
Next I pulled my brake booster line and put a funnel in it to put the Seafoam in, I figured that I would be in bed in about 30 minutes, I started the Blazer then came around to the front , started to pour in the Seafoam a trickle this went on for about a minute, Ive done this a few times before and I started to get bored, I poured in about a third of the can, then I turned off the truck, I then went back to the front of the truck and procceeded to dump the rest of the bottle into the booster line!! I went into the house and sat for about 15 minutes, I came back outside and turned the key on the truck expecting to see a big plume of white smoke, No smoke, no start ,nothing, Just a big Kerchunk!! I HYDRO LOCKED MY ENGINE!!!!! Needles to say I have spent the last three hours working on my engine!!! I pulled the spark plugs and a sea of Seafoam flowed from each and everyone of them.
Just a warning do not use the whole bottle!! 1/3 is enough!!! My Blazer is now running again ,I am so tired, My feet and hands are frozen, But one good thing did happen I found a sparkplug wire that was burnt in half from the Header's!!!!!!!!!!
Old 02-27-2006, 01:48 PM
billibong's Avatar
billibong billibong is offline
Re: Stupid!stupid!stupid!!stupid!!!stupid!!!
So, your truck is running now. Glad to hear that.
What is the proper method for using Seafoam? I understand that you are supposed to put 1/3 of the bottle into the throttle body or carbuerator - depending on what you have - and 1/2 bottle into the crankcase, when you do an oil change. I understand that you can use a whole can in the gas tank - with a fill-up. Why do you put it into you're brake booster line? I hadn't heard of that application.
Please forgive me if I sound uninformed - it's only because I am...
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 02-27-2006, 02:02 PM
SComp23 SComp23 is offline
You suck it in through the vacuum system, hence the break booster
Old 02-27-2006, 08:10 PM
It's the best and easiest way to get seafoam into it! I can tell you that it does work, the carbon on the sparkplugs just wiped right off.
Old 02-27-2006, 08:30 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
You have to modulate the throttle and keep the rpms close to 2000 while you are doing it and it is best to use a smaller line like the pcv line for introducing a substance like that seeing it will slow how much is taken in.
A proper application procedure will allow you to injest a whole seafoam can properly.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-28-2006, 06:17 AM
I am thinking about putting a t splice on one of the lines to make it easier to get to for the next time that I do a carbon cleaning. I don't have that much access to the top of the engine, I have to remove a few ducts.
Old 02-28-2006, 01:49 PM
BlazerLT's Avatar
AF -Advisor
PCV line should be easy to access though.
Old 02-28-2006, 02:41 PM
billibong's Avatar
Thanks for the input and response. I picked some Seafoam and plan on doing it this weekend.
Blazer SS, hope I didn't step on your thread. Apoligies if I did...
billibong
Repairs:
Old 02-28-2006, 02:45 PM
BlazerLT's Avatar
AF -Advisor
Just remember to allow it to suck in slowly through the PCV line at higher rpms close to 2000 on the tach, and make sure you have easy access to the throttle linkage so you can modulate it as the seafoam tries to kill the engine.
Old 02-28-2006, 07:52 PM
No problem, I will remember to keep the RPM's up next time.
Old 03-01-2006, 03:20 AM
GirlBear's Avatar
GirlBear GirlBear is offline
I wait til im on extreme E. Hit Advance Auto for Sea Foam. Go to Gas station. Pour in entire can then Fill'er up. Actually did this sunday night. @nd doin it this way .
http://jowulf.deviantart.com/
Old 03-01-2006, 03:22 AM
BlazerLT's Avatar
AF -Advisor
Won't do much diluted like that.
Old 03-01-2006, 09:49 AM
Not to mention thats how I blew up my fuel pump
Old 03-28-2006, 01:19 PM
bongabilla bongabilla is offline
Send a message via AIM to bongabilla
On the subject of seafoam I was told by a friend that immediately following the treatment you should change your oil (makes sense) but he also told me that you would also have to replace all the 02 sensors because carbon build up gets put on them........ I was just wondering if there was any truth to this?
