Old 02-27-2006, 01:54 PM
rahl rahl is offline
93 lumina driver door
handle has gone and tried to open it manualy after taking of panels and such but still cant figre it out. does anyone have a diagram i can use?
Old 02-27-2006, 05:40 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 93 lumina driver door
Handle gone inside and out? Or one broke and the other doesn't work?
If you still have one, but it doesn't work, you'll have to look for a rod type linkage inside the door that has stretched or popped off the handle mechanism.
If you have to, take the other door apart and see what's different inside them. I tried to find a diagram, but had no luck.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 02-28-2006, 09:27 AM
thanks for the reply. the door wont open from inside nor outside. took all the paneling off but cause of all the metal inide the door its almost impossible to get my hand in there to do anything at all.
Old 01-24-2007, 01:39 PM
mattnbj's Avatar
mattnbj mattnbj is offline
Thumbs up Re: 93 lumina driver door
i had that exact problem when i bought my 93 lumina ... inside the door is a rod ... and all it is was the rod was slightly bent ... i bent it back and works like a charm now ...
mattnbj's Avatar
Old 01-25-2007, 10:03 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The rod from the outside door handle goes into the top of the latch and pushes down as you lift the handle to release. If the handle broke, the rod may have fallen out as there is no retainer clip at the latch, just at the handle.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
