97 GXE No Power/Whine/Shaking
My car has run 220k miles as of last week, and for about a year it's reeeeally slow at acceleration. When I first got it I could top at at twenty mph increments per gear, now it's down to ten. Clutch?
Also whenever I get higher in gears I seem to hear a faint airy whining, any suggestions? Whenever I hit about 60mph+ my car starts to shake....a lot. But I'm replacing the cv joints as both are torn and then getting it realigned, whenever I slow to a stop the car rocks because it obviously needs it. But is this the only reason my car is shaking? College kid that could really use some tips before wasting money he doesn't have...thanks! |
Re: 97 GXE No Power/Whine/Shaking
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec. VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec. ![]() Don't make me ANGRY Or I will kick you in teh NUTS Your NUTS will feel teh steel toe Teh steel toe that has been in teh snow I will rip off yuor pants and kick yuo in teh nuts My steel toe will stick to yuor nuts And I will swing yuo around by yuor nuts as I do a Hurricane kick |
So let me see....
If you were traveling in 1st gear and reached 20mph and the car started shaking, then shifted to 2nd, the shaking would stop until you increased speed in 2nd? If so, the problem can't possibly be anything to do with axles, cv joints or anything like that. It seems to be rpm related. You could be misfiring, but the motor would be shaking all the time, even at idle. I don't know much about transmissions, but it sounds like that's your problem. Because the motor would be shaking all the time(not just at higher rpms), and the drivetrain would shake consistently over a certain speed, that only leaves the "input" side of the tranny. It's hard to explain when I don't know much about trannys, but the problem has to be in the "beginning" part of the tranny where the speed of the "sun" gear matches the motor's speed, before the ratios change from one of the five "planetary" gears. So, basically, it's in the clutch, flywheel, "sun" gear areas.
The car would be misfiring and stuttering. The motor wouldn't be smooth or consistent at all.
