Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-27-2006, 09:40 AM
billindelicato's Avatar
billindelicato billindelicato is offline
Update to the clunking
turns out after trial and error with the rear leaf spring bushings and body mounts the clunking had absolutely nothing to do with either...i discovered that the problem is a bad carrier bearing between the two drive shafts...now all i have to do is find one cheap enough any suggestions? anyone else had to replace this?
1998 Chevy Blazer LS 4x4
1996 Ford Dunderbird LX 3.8L
Old 02-27-2006, 10:10 AM
Ramblin Fever Ramblin Fever is offline
Re: Update to the clunking
Yeap! Mine fortunately was covered under warranty when it only had 20k miles on it.
It took a drive-line shop to find it though, the dealership did fix it via the write-up from the drive-line shop. Initially the dealership kept saying nothing was wrong with the truck - found out the hard way, almost causing an accident, as I was towing the boat and I had to make a pretty hard stop, major clunk!
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
